Need help: 7 times more Mass Flow out than in |
June 14, 2012, 12:31 |
Simon
Rep Power: 14 |
Hello!
I want to simulate the Battery-Cooling of a formula student car. I implemented a radial fan, like in the rigid body motion tutorial Inlet: Velocity (15m/s) Outlet: Pressure Implicit unsteady Ideal Gas K-Epsilon Turbulence Gravity Three Dimensional Surface Remesher Polyhedral Mesher Prism Layer Mesher (2) If I try Coupled Energy, the outgoing Mass Flow is going to be 7 times bigger than the incoming Mass flow. It is still increasing. Please help me! Enjoy it. Have a nice day! ( Please excuse my bad English) |
June 14, 2012, 12:37 |
Simon
Rep Power: 14 |
How can I put pictures in here?
June 14, 2012, 12:38 |
Simon
Rep Power: 14 |
June 15, 2012, 04:33 |
Rep Power: 17 |
Try to monitor mass flow rate with manual reports of density and velocity. Regards |
June 15, 2012, 16:42 |
Rep Power: 22 |
A mass flow report at each inlet and outlet should be fine to judge the mass imbalance.
How long did you run it? What about your time step size? Is it small enough? What about the convective courant number? Residuals? How does the flow field look like, is it reasonable? In my experience, the coupled solver needs a long time until a reasonable flow field has established. So although CD-adapco recommends the coupled solver when ressources are no issue, I would stick to the segregated solver when there are no high mach numbers involved. Or at least try to initialise as good as possible. When the setup is right and you run it long enough, the coupled solver will give you the same mass flow in and out for sure (assumed, you're looking on average values over a long enough period).
We do three types of jobs here: GOOD, FAST AND CHEAP You may choose any two! |
fan, invreasing mass, mass flow rate, rotating |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 22:11 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 18:57 |
Mass Flow Rate | student87 | CFX | 4 | January 2, 2010 05:45 |
mass flow | Wenbin Song | FLUENT | 0 | September 27, 2005 14:00 |
different mass flow rates | michael | FLUENT | 4 | February 21, 2005 04:48 |
