December 16, 2024, 20:12 |
greenhouse simulation
sabrina taieb
Dear all,
I am simulating a greenhouse to study the temperature, humidity, and solar radiation inside. However, I am facing an issue where the radiation values are significantly higher than expected. For example, I have a global solar radiation of 621 W/mē, but the simulation results show radiation values exceeding 3000 W/mē. I have thoroughly checked the material properties of polyethylene and I am not using any UDFs. *using DO model Thank you very much in advance! |
Unsteady Subsonic Nozzle Flow Simulation Issue with SU2 | Madsskjaerbaek | SU2 | 3 | April 17, 2024 10:41 |
Convergence Problem - Transient Simulation | gemxx | Main CFD Forum | 0 | July 15, 2018 10:36 |
Mapping Field Data for Mesh Regions from Another Simulation | veterator | OpenFOAM Pre-Processing | 1 | July 10, 2018 06:28 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
