June 4, 2013, 16:29 |
#21 |
Dear Jola
My opinion was to make the sub-forums and people here have different views. But I see every person (who is in favor of sub-forums) has different preferences for sub-forums. So my recommendation is to keep the forum " as it is " until we get more suggestions. What do you suggest? |
June 4, 2013, 18:36 |
#22 |
Administrator
Might be a good idea to wait a bit. Perhaps we could try to find one or a couple of very specific sub-forums to open to start with, like the UDF forum we have now. The UDF forum seems to work quite well, but that is a very easy topic to separate. I'll think about another good topic to separate, nothing comes to my mind directly.
June 5, 2013, 08:10 |
#23 |
OJ
Rep Power: 20 |
Personally, I vote for the classification based on applications themes for the reasons I mentioned in earlier post. However I think that any kind of classification into sub-forums that majority of folks agrees upon will be beneficial.
While the list of application themes is pretty exhaustive, we can consider the following list: 1) Aerodynamics/turbomachinary 2) Heat transfer/Combustion 3) Mulitphase 4) UDF 5) Main/Miscellaneous The themes can be added/subtracted/separated as folks deem fit. OJ |
June 5, 2013, 08:25 |
#24 |
well, "multiphase" would be better choice to segregate first. Audience of this topic is growing at rapid rate.
Another choice can be "convergence, turbulence modeling, transition modeling, solver settings" Third choice is "General/Main/Miscellaneous Fluent forum" |
June 5, 2013, 12:19 |
#25 |
Administrator
Peter Jones
Rep Power: 10 |
I agree with you Sijal. Since we can't find a forum subdivision that everyone agrees on lets add only one subforum to start with and see how it works out. Multiphase is a topic that is easy to separate and also has a a growing dedicated audience. I have opened a new Fluent Multiphase subforum now. I will start moving threads from the main forum into the new subforum to give it some content to start with. Feel free to help with this.
June 5, 2013, 12:23 |
#26 | |
Ghazlani M. Ali
Rep Power: 29 |
This is funny, i was browsing the fluent section, and headed to the oldest and first thread back in november 1999, this is what it says :
June 5, 2013, 13:48 |
#27 | |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 11:26 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 07:22 |
Alias problem when starting FLUENT from command line | batch_error | FLUENT | 0 | May 24, 2012 09:20 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
