May 16, 2023, 09:03 |
PhD position - REEF3D & sediment transport
Hans Bihs
Rep Power: 18 |
As part of the ERC Consolidator grant “Particle Resolving Fluid-Sediment Interaction” (PARTRES), we have a
vacancy for a 3-year PhD position at the Department of Civil and Environmental Engineering within the Marine Civil Engineering group. Representing the interconnected processes of current, waves and sediment transport constitutes an interdisciplinary challenge. In the current PhD project, a particle-based sediment transport model will be created. Together with the underlying high-resolution and turbulence resolving flow solver, this will take a step towards a more realistic representation of these processes. The sediment transport will be described through a particle centric numerical framework. The turbulent flow calculations will be performed on a Eulerian background mesh using an immersed boundary method for the solid boundaries and a two-phase flow solver to capture complex free surface dynamics. The numerical model used for those activities is the open-source hydrodynamics framework REEF3D (www.reef3d.com). The model is developed in-house and the candidate will be a member of the research team. The new sediment particle transport model will be implemented in REEF3D through a generic particle framework that is parallelized for domain decomposition. Please find the link to the application portal and detailed job description: https://www.jobbnorge.no/en/availabl...ment-transport |
how to code suspended sediment transport equation in interFoam | sourav8016 | OpenFOAM | 0 | June 12, 2021 15:15 |
Sediment Transport | abhinavsaketh | Fluent Multiphase | 0 | June 5, 2018 03:40 |
Advice for PhD Position Interview | H0T_S0UP | Lounge | 4 | August 3, 2015 14:40 |
searching for phd position in industry where i can develop openfoam applications | aujamal20 | Lounge | 1 | September 3, 2013 02:25 |
PhD position on on Euler-Euler quadrature-based multiphase flow models and OpenFOAM | alberto | OpenFOAM Announcements from Other Sources | 2 | July 10, 2012 13:22 |
