[OF1.6-ext] icoFsiFoam not present
Old   April 14, 2012, 11:40
Default -solved- [OF1.6-ext] icoFsiFoam not present
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
Dear All.
I'm starting to perform some Fsi simulations with openfoam.
after some googling i've found that icoFsiFoam might be what i need so, in order to start playing with it and not mess up with my 2.0.x machine, i've set up a Vm in virtuabox, installed ubuntu 10.04 lts and installed OF1.6-ext -dev -docs from the binaries, following the howto on the wiki http://openfoamwiki.net/index.php/In...ucid_10.04_LTS
all went good and well. everything is working fine, meaning that who took kare of making such a complex sw available as a distributuion did a fantastic job.
unfortunately i cannot find the fsi solver. from what i've read in the forum:
http://www.cfd-online.com/Forums/ope...-not-work.html
http://www.cfd-online.com/Forums/ope...-problems.html
it is ported to the 1.6-ext (page 3 of the second link, now working in parallel) and tutorials for it should be found in /usr/shared/doc/openfoam-1.6-ext/examples/stressAnalysis but it isn't here.
any suggestions or ideas to help me get it up and running will be welcome.
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   April 14, 2012, 11:58
sail's Avatar
Vieri Abolaffio
nevermind, i found a testcase here http://www.cfd-online.com/Forums/ope...cofsifoam.html and managed to test the installation. it actually works.
thanks again.
Ps, if anybody have others case files, i'd be glad to take a look at them.
Old   April 16, 2012, 12:32
Elvis
elvis will become famous soon enough
Hi Vieri,
http://www.openfoamworkshop.org/6th_...m/training.htm
http://www.openfoamworkshop.org/6th_...ell_slides.pdf
http://www.openfoamworkshop.org/6th_...mpbell_fsi.tgz
elvis is offline   Reply With Quote
Benchmark for Fluid-Structure Interaction solver (IcoFsiFoam) Eferal OpenFOAM 3 October 3, 2013 04:04
icoFsiFoam in OF1.6-ext does not work mechy OpenFOAM 4 July 26, 2011 04:14
icoFsiFoam case needed vivekcfd OpenFOAM 1 May 6, 2009 14:41
IcofsiFoam not supported under released 141 package pi06jl6 OpenFOAM Running, Solving & CFD 4 June 26, 2008 14:59
Errors in running a icoFsiFoam case jin_xu OpenFOAM Pre-Processing 0 June 9, 2008 07:48
