The new SIMPLE/PIMPLE loop control structure in OF 2.1
Old   April 10, 2012, 10:23
Default The new SIMPLE/PIMPLE loop control structure in OF 2.1
Illya Shevchuk
linch is on a distinguished road
Hi guys,
since OF 2.1 there is a new control structure for SIMPLE & PIMPLE loops. So now the outer PIMPLE loop looks just like:
while (pimple.loop())        {...}
I would like to know how to use it properly. I mean, how can one define convergence criteria for the outer iteration loop?
I tried to look into the pimpleControl.C and hier it is:
bool Foam::pimpleControl::loop()
00174 {
00175     read();
00176
00177     corr_++;
00178
00179     if (debug)
00180     {
00181         Info<< algorithmName_ << " loop: corr = " << corr_ << endl;
00182     }
00183
00184     if (corr_ == nCorrPIMPLE_ + 1)
00185     {
00186         if ((!residualControl_.empty()) && (nCorrPIMPLE_ != 1))
00187         {
00188             Info<< algorithmName_ << ": not converged within "
00189                 << nCorrPIMPLE_ << " iterations" << endl;
00190         }
00191
00192         corr_ = 0;
00193         mesh_.data::remove("finalIteration");
00194         return false;
00195     }
00196
00197     bool completed = false;
00198     if (converged_ || criteriaSatisfied())
00199     {
00200         if (converged_)
00201         {
00202             Info<< algorithmName_ << ": converged in " << corr_ - 1
00203                 << " iterations" << endl;
00204
00205             mesh_.data::remove("finalIteration");
00206             corr_ = 0;
00207             converged_ = false;
00208
00209             completed = true;
00210         }
00211         else
00212         {
00213             Info<< algorithmName_ << ": iteration " << corr_ << endl;
00214             storePrevIterFields();
00215
00216             mesh_.data::add("finalIteration", true);
00217             converged_ = true;
00218         }
00219     }
00220     else
00221     {
00222         if (finalIter())
00223         {
00224             mesh_.data::add("finalIteration", true);
00225         }
00226
00227         if (corr_ <= nCorrPIMPLE_)
00228         {
00229             if (nCorrPIMPLE_ != 1)
00230             {
00231                 Info<< algorithmName_ << ": iteration " << corr_ << endl;
00232                 storePrevIterFields();
00233             }
00234
00235             completed = false;
00236         }
00237     }
00238
00239     return !completed;
00240 }
the first check is done to see if the maximum number of iterations is exceeded
if so,
what does it mean?
Then convergence is checked
my question here is, why are there two different indicators of convergence "converged_" and "criteriaSatisfied()"? Where can one provide the criteria to be satisfied? I also looked on the bool Foam:impleControl::criteriaSatisfied(), but it also wasn't easy to understand, what is being done there.
I would really appreciate, if someone takes some time and explains it for such noobs as me.
Best regards,
Illya
linch is offline   Reply With Quote
Problems of running Oscillating plate tutorial vovogoal CFX 20 February 4, 2016 08:03
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
error in two way fsi kmgraju CFX 1 May 2, 2011 03:32
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
