April 2, 2012, 05:34 |
Cell Handeling
yudhast
Rep Power: 15 |
I want to collect the cell information and the pressure at nearby cells with their x and y co-ordinates as follows: Co- ordnates(X Y) ... Cell Value (Pressure)(P).... neighboring cells(Pressure)(p1,p1,p3,p4) Please tell me how to extract these information? Thanks & Regards, Yudhast |
April 2, 2012, 05:39 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Yudhast
You can use the cellCells() member function in fvMesh, which returns the indices for the neighbouring cells. E.g. Code:
label cellI( 0 ); // The cell you are considering const labelList & cellCells( mesh.cellCells()[cellI] ); // Pressure, p, in neighbouring cells: forAll(cellCells, celli ) { Info << p[cellCells[celli]] << endl; } Niels |
April 2, 2012, 06:27 |
#3 | |
yudhast
Rep Power: 15 |
Thanks for your reply.. Suppose I have to put a condition on the cell eg. For all the cells if X != 0 where X=interface.sigmaK()*fvc::grad(alpha1) How to do this?? Regards, Yudhast |
October 3, 2012, 20:42 |
east and north cell values
Rep Power: 14 |
Is there any way (any function) to get the value of a parameter at the east and north of a specific cell?
April 10, 2013, 08:49 |
ABE
Rep Power: 14 |
Hi Niels,
I would be thankful if you could help me. I want to add a loop right after solving the pressure equation to calculate a new pressure field based on: newP(cell)=(30*P(cell) + p(neighbours) )/(30+No.neighbours) Does the following work for it? const vectorField& cCentre = mesh.C(); const labelListList& neighbour = mesh.cellCells(); double pTemp=0.0; int i=0; forAll(cCentre, celli) { labelList nCellID = neighbour[celli]; pTemp=0.0; i=0; forAll(nCellID,cellNe) { pTemp+=p[cellNe]; i+=1; } pTemp+=30*p[celli]; p[celli]=pTemp/(30+i); } Thank you in advance... |
April 10, 2013, 09:51 |
Rep Power: 37 |
Hi Abe,
Yes, it does look like it would produce the thing you are after; sort of! First of all you are putting the computed value back into the field, which you are using as a source, so the final weighting cannot be predicted. Secondly, this will only work for serial computations, as the weighting does not take the neighbouring cells on other processors into account. Thirdly, the cellCells are only returning the cells, which have a face in common with the cell of interest. If you want all of the cells connected to the cell, i.e. also connected through a common point, then you would need to use pointCells and make a unique list of connected cells. Unique, because the pointCells information will give you multiple occurrences of the connected cell labels. Fourthly. Are you really sure that this is what you want? Changing the pressure after its solution will essential/potentially ruin the pressure-velocity coupling. Good luck, Niels |
April 10, 2013, 10:22 |
ABE
Rep Power: 14 |
thank you for your complete answer.
I am going to simulate cavitation in a complex geometry, and I just want to create a smoother pressure field in first few iterations. PS: thanks for your hint about parallel issue... ABE |
cell data, openfoam, pressure |
How to determine the direction of cell face vectors on processor patches | sebastian_vogl | OpenFOAM Programming & Development | 1 | October 11, 2016 13:17 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
How to determine the direction of cell face vectors on processor patches | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | October 27, 2009 08:47 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
