April 1, 2012, 06:37 |
Bubble column on modelling Openfoam
Philip Donnellan
Rep Power: 14 |
I am setting about modeling a partiqular type of bubble column involving an electrolytic solution, and I am trying to select the right CFD sofware to achieve this. The package would have to be able to model mass transfer, heat transfer and of course the fluid flow profile. This is my first time using CFD, and therefore the most user friendly software would or course be prefered. Also my budget for achieving this research is not very big, and therefore if there was open source software that could be used it would be best. If anyone has any tips or advice for me it would be hugely appreciated. Thanks! |
April 2, 2012, 08:38 |
Rep Power: 16 |
Hello chemical engineer.
A bubble column has been simulated before with OpenFOAM. There is a tutorial case called bubbleColumn. For the theory, you should read the Henrik Rusche's thesis. Download it from http://foamcfd.org/resources/theses.html If you want to start with OpenFOAM, you might go to the OpenFOAM Workshop, where they give excellent introductory courses: http://www.openfoamworkshop.org/2012/OFW7.html Have fun! |
April 4, 2012, 04:24 |
#3 | |
Philip Donnellan
Rep Power: 14 |
Thanks again!! |
April 4, 2012, 12:02 |
Rep Power: 16 |
Find it in
- OpenFOAM/OpenFOAM-2.0.x/tutorials/multiphase/bubbleFoam/bubbleColumn - OpenFOAM/OpenFOAM-2.0.x/tutorials/multiphase/twoPhaseEulerFoam/bubbleColumn PS: you can find this yourself if you type: Code:
find -iname bubbleColumn |
bubble column, cfd, code selection, modeling cfd, openfoam |
Experts in Simulating BUbble Column Reactors | aliyah | Main CFD Forum | 7 | June 19, 2012 03:38 |
bubble column | anand | FLUENT | 1 | March 14, 2006 16:11 |
Bubble Column | Glen | Main CFD Forum | 0 | January 24, 2006 01:56 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 01:02 |
bubble column reactor | atin asodekar | Main CFD Forum | 0 | June 15, 2000 06:40 |
