wmake error
Old   March 26, 2012, 11:52
Default wmake error
Jian Zhong
zxj160 is on a distinguished road
I copied the channelFoam application files and change the name of the .C file to newchannelFoam (aslo in the make file) and the path to user directory. I wmake it and it seems OK.
Then I run the channelFoam tutorial case: blockMesh and newchannelFoam. The error message is as follows:
bash-3.2$ newchannelFoam
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by newchannelFoam)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by newchannelFoam)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libmeshTools.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libmeshTools.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libLESdeltas.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libLESdeltas.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libLESfilters.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libLESfilters.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libtriSurface.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libtriSurface.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfileFormats.so)
newchannelFoam: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfileFormats.so)
zxj160 is offline   Reply With Quote
wmake error
Problem running perturbUCyl sen.1986 OpenFOAM 17 June 4, 2019 06:56
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
