AMI (GGI) to connect 2 parts
Old   March 12, 2012, 17:29
Default AMI (GGI) to connect 2 parts
Hannes
falke126 is on a distinguished road
Hi to all,
I would like to use 2 stationary parts in a simulation, which are not 1:1 connected by the meshes...
In CFX I just use a ggi to connect them.
Now I would like to test this in OF. Has somebody done this in OF by the new AMI in OF210 and can give me a short advice?
Best regards,
Hannes
falke126 is offline   Reply With Quote
Old   March 13, 2012, 03:05
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi look at this tutorial
OpenFOAM-2.1.x/tutorials/incompressible/pimpleDyMFoam/propeller/
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 13, 2012, 15:01
Hannes
Thanks for your response,
i´ve had a look in these tutorials (propeller and the mixerVessel).
My problem is, that in these tutorials the AMI is used for cyclic sections and the interface is some kind of a cylinder barrel...
But I want to use it for a planar circular interface... e.g. to connect two pipe sections.
I hope the problem definition is clear...
I would be pleased, if someone can help me.
Best regards,
Hannes
Old   March 13, 2012, 15:07
linnemann's Avatar
Niels Nielsen
Hi
Its exactly the same approach.
You just couple two patches, dont matter if they are square/cylinder/disk/plane.
As long as they match sufficiently you're good to go
Linnemann
Old   March 13, 2012, 15:50
Hannes
that sounds good
So I just define the 2 patches of type cyclicAMI?
Are there further steps to do, to get the case running?
At the moment I´m not sure, what steps of the propeller tutorial
(e.g topoSet) are needed in my case.
Old   March 16, 2012, 04:40
Christian Lucas
Chris Lucas is on a distinguished road
you could also have a look at the ggi tools in OpenFOAM-1.6 ext.
Best Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   March 20, 2012, 10:04
Hannes
In the last days I tried another approach - to connect the 2 pipe parts by the mergeMesh + stitchMesh utilities in OF.
Principally that works not so bad. But sometimes non-orthogonal faces are generated. ( *-warning in checkMesh (not ***))
Now I´m thinking about, what is better?
- AMI (GGI) with the original good quality mesh
- direct connection with a slightly worser mesh quality
Best Regards,
Hannes
Create a GeometricField of a given type on given patch? philippose OpenFOAM Programming & Development 4 August 12, 2013 13:41
Ggi FabOr OpenFOAM 17 May 9, 2013 11:19
GGI Tolerance taner OpenFOAM Running, Solving & CFD 18 February 12, 2013 16:58
Difference between ggi and overlapGgi? GGI Tips and Tricks? philippose OpenFOAM Running, Solving & CFD 7 January 16, 2013 10:40
GGI in OpenFOAM-1.5-dev philippose OpenFOAM Running, Solving & CFD 14 November 13, 2011 15:55
