BC in a volume
Old   February 24, 2012, 06:04
Default BC in a volume
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I am trying to set a BC in a volume and not on a surface. In other words, I want that a certain volume in my domain has a certain fixed temperature. Of course, this condition is much stronger than imposing the temperature on the surface, isn't it?
Do you have an idea if it is possible (if yes, could you tell me how, please) do what I would like to do?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   February 24, 2012, 07:27
Laurens Van Dyck
laurensvd is on a distinguished road
You could modify your solver by adding some lines that checks the position of a cell
If that cell is then in the region you want it overwrite the calculated value with your own fixed value.
laurensvd is offline   Reply With Quote
Old   February 24, 2012, 07:30
Samuele Z
Actually, I am reading about the setValues function that is available in OpenFOAM.
In fact I know the label of the cells I want to fix the value in.
Do you know something about this?
Thanks a lot,
Samuele
Old   February 24, 2012, 10:17
Samuele Z
Also, I forgot to write that I am running OF 2.0 and am using the solver buoyantSimpleFoam.
Furthermore, I can not und which is the righ file to edit. I checked this thread, too. But I can't find the right file to edit.
Could you help?
Thanks a lot,
Samuele
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
