boundary conditions turbine
Old   February 22, 2012, 16:05
Default boundary conditions turbine
Florian
riesotto is on a distinguished road
Hi All,
I want to simulate the flow in a turbine with the rhoPorousMRFSimpleFoam.
Until now I have simulate the flow in a centrifugal compressor . Therefor I have done some experimental studies with the compressor. I have measured the flow rate for different rotation speed (rpm). Then I used this data for my boundary conditions:
- for the velocity U
inlet: fixed value for U (from the measured data)
outlet: zeroGradient
- for p
inlet: zeroGradient
outlet: fixed value (measured data)
The simulation works and I get a convergent case (not sure the results are right, but they look reasonable).
Now I want to simulate the compressor as a turbine. In this case, the fluid flows from the "outlet" into the compressor and exits the compressor from the "inlet".
For my first simulation of the turbine I used the experimental data of the compressor and reverse the direction of rotation. Additionally I change the inlet and the outlet.
But I get bad convergence and very high velocity at the rotor. The results looks very unreasonable. I am a little bit confused.
What are the right boundary conditions for simulate a turbine with rhoPorousMRFSimpleFoam ?????
Is there a real difference between a simulation of a turbine and a compressor???
Please help
Kind regards
Florian
riesotto is offline   Reply With Quote
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
boundary conditions for a rotating wind turbine problem amoolraina FLUENT 0 December 22, 2010 11:40
Simulation of Pelton Turbine: boundary conditions? massimo CFX 0 September 26, 2006 04:56
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
