Error when doing the computations
Old   February 12, 2012, 22:37
Post Error when doing the computations
Melika
libra is on a distinguished road
Hi everyone
I am simulating the water flow in a pipe with channelFoam. I could start the computations but it stopped after a few hours and I got this error:
[olcs03:31646] [ 4] /home/naka/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam33limitedSurfaceInterp olationSchemeIdE7weightsERKNS_14GeometricFieldIdNS _12fvPatchFieldENS_7volMeshEEE+0x2a) [0x7f4e637260ca]
[olcs03:31646] [ 5] /home/naka/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so(_ZNK4Foam2fv21gaussConvectionSc hemeIdE6fvmDivERKNS_14GeometricFieldIdNS_13fvsPatc hFieldENS_11surfaceMeshEEERNS3_IdNS_12fvPatchField ENS_7volMeshEEE+0x5c) [0x7f4e6372e72c]
[olcs03:31646] [ 6] /home/naka/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam3fvm3divIdEE NS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldId NS_13fvsPatchFieldENS_11surfaceMeshEEERNS7_IS4_NS_ 12fvPatchFieldENS_7volMeshEEERKNS_4wordE+0x81) [0x7f4e6430d171]
[olcs03:31646] [ 7] /home/naka/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam3fvm3divIdEE NS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldId NS_13fvsPatchFieldENS_11surfaceMeshEEERNS7_IS4_NS_ 12fvPatchFieldENS_7volMeshEEE+0xf2) [0x7f4e643110f2]
[olcs03:31646] [ 8] /home/naka/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompress ible9LESModels9oneEqEddy7correctERKNS_3tmpINS_14Ge ometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7v olMeshEEEEE+0x48c) [0x7f4e64329bfc]
[olcs03:31646] [ 9] /home/naka/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleLESModels.so(_ZN4Foam14incompress ible8LESModel7correctEv+0x35) [0x7f4e642b1665]
[olcs03:31646] [10] channelFoam [0x41773c]
[olcs03:31646] [11] /lib/libc.so.6(__libc_start_main+0xe6) [0x7f4e61a2a1a6]
[olcs03:31646] [12] channelFoam(_ZNK4Foam11regIOobject11writeObjectENS _8IOstream12streamFormatENS1_13versionNumberENS1_1 5compressionTypeE+0xc9) [0x416449]
[olcs03:31646] *** End of error message ***
^C
naka@olcs03:~/OpenFOAM/naka-1.6.x/run/melika/case7$
naka@olcs03:~/OpenFOAM/naka-1.6.x/run/melika/case7$ tail -f log
Can anyone help me with that?
libra is offline   Reply With Quote
Old   February 13, 2012, 15:44
Nima Samkhaniani
nimasam is on a distinguished road
it seems its related your schemes in fvScheme,
put your fvScheme here. may some one can help you
nimasam is offline   Reply With Quote
Old   February 14, 2012, 22:46
Melika
For my case fvScheme is as follows:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss filteredLinear2V 0.2 0;
div(phi,k) Gauss limitedLinear 1;
div(phi,B) Gauss limitedLinear 1;
div(phi,nuTilda) Gauss limitedLinear 1;
div(B) Gauss linear;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DBEff,B) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
However it seems that there is something wrong with "courant number". During the computations it gets bigger and bigger and finally the computation stops.
Old   February 15, 2012, 03:50
Nima Samkhaniani
i dont know where the problem is but could you change limited linear schemes into upwind schemes! and report the result?
Old   February 23, 2012, 22:30
Melika
Thanks nimasam
Problem solved. There was sth wrong with the offset value. I needed to define it in the opposite direction.
Program for pre- and postprocessing computations Evelina OpenFOAM 2 June 2, 2011 20:13
Computations with eighty million cells Armin OpenFOAM 8 January 7, 2011 15:15
Computations with eighty million cells Armin Main CFD Forum 0 December 28, 2010 07:47
Problems of running the parallel computations lorraine FLUENT 17 July 6, 2007 09:08
Fan Computations Keen FLUENT 0 April 27, 2007 05:42
