Eclipse - case debug error
Old   February 3, 2012, 14:38
Smile Eclipse - case debug error
Paulo Bufacchi
Bufacchi is on a distinguished road
Hi Foamers,
I'm running OpenFOAM 2.1.x on OpenSUSE 11.4 64 bits.
I downloaded Eclipse IDE for C/C++ Developers (includes Incubating components), for 64 bits. It is version Indigo (3.7) Service Release 1.
Thanks to the Wiki http://openfoamwiki.net/index.php/Ho...M_with_Eclipse installation and configuration ran smoothly. I also read the thread http://www.cfd-online.com/Forums/ope...-openfoam.html.
I imported the icoFoam solver and cavity case as projects to my workspace. Prior to that I ran blockMesh.
When I run the case, it goes well, without errors. But when I debug it, I have the following error:
Debug Perspective:
Console Window:
Missing separate debuginfo for /usr/lib64/libstdc++.so.6
Try: zypper install -C "debuginfo(build-id)=e87ebb28b8b5aa032cf2925387aaa13f2cb93c90"
Missing separate debuginfo for /lib64/libm.so.6
Try: zypper install -C "debuginfo(build-id)=5ac64cd348d3581ec2a223ee70f42e73cad029cc"
Missing separate debuginfo for /lib64/libgcc_s.so.1
Try: zypper install -C "debuginfo(build-id)=e6eb8011838a065946e5808e036550844548379f"
Missing separate debuginfo for /lib64/libc.so.6
Try: zypper install -C "debuginfo(build-id)=70bab20280816eb26a0553f13382ee75d53179f5"
Missing separate debuginfo for /lib64/libpthread.so.0
Try: zypper install -C "debuginfo(build-id)=e23cbc772e670af00bea9874f925e2e61afda713"
[Thread debugging using libthread_db enabled]
Missing separate debuginfo for /lib64/libz.so.1
Try: zypper install -C "debuginfo(build-id)=61e4e9a46287c10135232e8a269575a1ceda7638"
Missing separate debuginfo for /lib64/libnsl.so.1
Try: zypper install -C "debuginfo(build-id)=2d5906a5f42a9ad6df5fc2f91ab5bca478ce4959"
Missing separate debuginfo for /lib64/libutil.so.1
Try: zypper install -C "debuginfo(build-id)=5751266e22e9f2cbca821b110e87ecd37e70e7b4"
Debug Window:
teste Debug (2) [C/C++ Application]
/home/paulo/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPDebug/bin/icoFoam [7003] [cores: 5]
Thread [1] 7003 [core: 5] (Suspended : Breakpoint)
main() at setRootCase.H:5 0x4409ed
gdb
/home/paulo/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPDebug/bin/icoFoam [7045] [cores: 6]
Thread [1] 7045 [core: 6] (Suspended : Breakpoint)
gdb
/home/paulo/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPDebug/bin/icoFoam [7098] [cores: 6]
Thread [1] 7098 [core: 6] (Suspended : Breakpoint)
gdb
/home/paulo/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPDebug/bin/icoFoam [7218] [cores: 1]
Thread [1] 7218 [core: 1] (Suspended : Breakpoint)
gdb
It is important to say that I'm not compiling an application. I'm running the case and I started Eclipse from the icon in its folder and not from a terminal.
How can I fix the error?
Thanks,
Paulo
Bufacchi is offline   Reply With Quote
Old   February 7, 2012, 16:15
Paulo Bufacchi
Case closed.
Reason for the error: repositories for debugging were not enabled in OpenSuse. After enabling them and running the zypper commands Eclipse run ok.
Thanks,
Paulo
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
