Rep Power: 14 ![]() |
Hi all,
I am currently working on a problem that involves fluid flow, and I am thinking on digging into OpenFOAM for this. But before that I want to ask whether it does the job. My problem is the following: I have a hot solid piece of equipment (later maybe with internal heat source) and a flow of cold air around it. I need to simulate the flow of air around it, i.e. how the air flow behaves when the air gets warmer, and how the temperature distribution inside the solid changes when the air cools it. So it is a problem of convective heat transfer between the solid and the fluid and conductive heat transfer inside the solid. Can OpenFOAM do this? And is there maybe even a tutorial for this? When I am new to OpenFOAM, what would be a good and effiecient approach to get there as quickly as possible? Thank you! |
Santiago Marquez Damian
Rep Power: 24 ![]() |
Yes, it can, but I think you have to program your own solver from potentialFoam, icoFoam and scalarTransportFoam
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
Tibor Nyers
Rep Power: 17 ![]() |
the chtMultiRegionFoam solver is a good candidate for the job. Although, IMHO, you have to get your hands dirty, there's only limited amount of information about case / boundary setup. But first of all, you need to advance step-by-step, so I would recommend you take a steady start with the simple solvers and cases, then proceed to the complex ones. |
Rep Power: 16 ![]() |
Toorop is right. The chtMultiRegionFoam solver should do what you want. But I suggest you should start with simpleFoam to get familiar with the OpenFoam structure.
"When I meet God, I am going to ask him two questions: Why relativity? And why turbulence? I really believe he will have an answer for the first." Werner Heisenberg
Thank you, chtMultiRegionFoam looks like it does, what I want. And yes, my first run of OpenFOAM will definetly not be my real case. I will look into simpleFoam first, as val46 suggested. Thank you! |
maddalena
Rep Power: 23 ![]() |
Hello gimmetwofingers (nice nickname
![]() I have made some investigation on http://www.cfd-online.com/Forums/ope...tml#post290772. You really have to get your hand dirty, not only on setting up a case, but also on letting everything work properly... Well... good luck! mad |
ooops... I thought in the meantime heat source is officially included in the multiregion solvers.
mad, have you ever got your solver running with heat source?
#8 | |
maddalena
Hi val46,
![]() mad |
heat and mass transfer, heat conduction |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
UDF convective heat transfer correlations | sarah | FLUENT | 0 | March 29, 2007 09:52 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
