Vortex induced Vibrations
Like Tree12Likes
Old   July 28, 2014, 09:01
Amit Dhage
Amit-1911 is on a distinguished road
Dear Araujo,
Do i need to input constraints for my body in dynamicMeshDict file?, because the same i had already inputed in pointDisplacement file.
Pls suggest.
Thanks and Regards,
Amit Dhage
Amit-1911 is offline   Reply With Quote
Old   July 28, 2014, 15:30
Leonardo Antonio de Araujo
araujo is on a distinguished road
Send a message via Skype™ to araujo
Originally Posted by Amit-1911 View Post
Dear Araujo,
Pls suggest.
Thanks and Regards,
Amit Dhage
Which openfoam version are you using? This varies from version to version.
araujo is offline   Reply With Quote
Old   July 28, 2014, 16:01
Amit Dhage
I am using version 2.2.2
Old   July 28, 2014, 16:50
Check out the pointDisplacement file. I believe there is something wrong with your constraints.
Old   July 29, 2014, 01:50
Amit Dhage
Dear Araujo,
I have checked the constraints many a times and really not finding any clue,
can you pls check the same file i am attaching herewith and suggest something.
Regards,
Amit Dhage
Old   July 29, 2014, 06:35
Dear Araujo,
Regards,
Amit Dhage
Center of mass on (0,0,0)? Is that correct? It is important to notice that the center of mass of the cylinder is referred relative to the domain position (your mesh).
Old   July 29, 2014, 06:50
Amit Dhage
Dear Araujo,
The centre of mass is specified w.r.t global coordinate system, and the domain is also specified w.r.t global coordinate system. Is this correct?
regards,
Amit Dhage
Old   August 21, 2014, 08:48
ok
Maimouna is on a distinguished road
Dear Amit,
my pointDisplacement file is attached. I hope that would be help.
All the best.
Maimouna is offline   Reply With Quote
Old   August 21, 2014, 08:50
ok
Sorry there is attached problem. Here it is
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class pointVectorField;
location "0.01";
object pointDisplacement;
dimensions [0 1 0 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
cylinder
type calculated;
value uniform (0 0 0);
top
type empty; //symmetry;
bottom
walls
type slip; //symmetry;
type fixedValue;
Old   August 21, 2014, 13:58
Amit Dhage
Dear Maimouna,
Thanks for your reply!
Are you able to produce results with point displacement file you sent to me?, since you have not imposed any constraints on the body, if so then i will try with the same.
Thanks and regards,
Amit Dhage
Old   August 22, 2014, 07:21
ok
Dear Amit,
constraints and resistance are imposed in dynamicMeshDict file. I'm still working on that to get the result.
Regards
Maimouna
Old   August 22, 2014, 07:33
Amit Dhage
Dear Maimouna,
I am not sure if that will work, because if you go through the tutorial of Wing motion...constraints and restraints are set in PointDisplacement file and not in dynamicMeshDict file.
Thanks and regards,
Amit Dhage
Old   August 22, 2014, 07:47
ok
Dear Amit,
you are right if you are using OF-2.2.2, but I'm using OF-2.3.0. So you will find the difference.
All the best.
Maimouna
Old   August 22, 2014, 08:10
Amit Dhage
oh is it?, then its fine...let me know if it works successfully.
Thanks and regards,
Amit Dhage
Old   August 27, 2014, 08:07
ok
Dear Leonardo,
what are your stiffness and damping values that you used in your case?
What about displacement? Where exactly did you set that?
Could you please provide us by that information to make more clarification.
Thanks and regards.
Maimouna
Old   September 16, 2014, 04:24
Alireza Heidari
alirezahd is on a distinguished road
Dear Araujo,
Regards,
Amit Dhage
dear Amit
i have run with your pointDisplacement file and the result shown the cylinder is stationary in different Re number (Re=100,150,200)
did you have same problem? and what did you do?
Thanks & regards
Alireza Heidari
maasyraf3 likes this.
alirezahd is offline   Reply With Quote
Old   November 23, 2017, 14:43
Default method
  #37
Naeem Ur Rahman
Naeem.rahman47 is on a distinguished road
Originally Posted by araujo View Post
Dear Amit,
I believe it has something to do with the "constraints" on your dynamicMesh dictionary. Check out if you set up the right axes and lines for your body to move.
Sir how you are simulating this project, with fluent and transient structural. If so then what constraint are you using for transient structural?
Thanks, please help me
Naeem.rahman47 is offline   Reply With Quote
6 dof, openfoam 2.1.0, pointdisplacement, tutorial, vortex induced vibrations
vortex induced vibration Simon Wang FLUENT 4 December 25, 2017 04:23
vortex induced vibration from dynamic mesh natto Main CFD Forum 4 April 18, 2015 20:42
"bit" phenomenon in Vortex Induced Vibration? JOEY Main CFD Forum 0 August 4, 2006 09:49
Vortex Induced vibration of subsea pipeline Mobasheri FLUENT 5 February 9, 2006 08:07
Flow induced vibrations Sujit Main CFD Forum 3 September 1, 2003 06:09
