compressible flow in turbocharger
Like Tree2Likes
Old   February 12, 2013, 16:19
immortality's Avatar
Ehsan
immortality is on a distinguished road
Originally Posted by jyothishkumar View Post
Hi Antonio,
I have tried as you mentioned in your reply. Please look at these
i. Changing the second order accuracy of riemann solver (in fvsolution file in system folder) like this
Riemann
secondOrder no; // activate 2nd order extensions
multidimLimiter yes; // Switch between 1D and mutliD limiters
epsilon 5; // VK constant
limiterName vanAlbadaSlope; // vanAlbadaSlope, MinmodSlope, vanLeerSlope
ii. Including Sutherlands theory in the thermophysicalproperties file like this
thermoType hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>;
iii. I dont find file like MRFdict as you mentioned in your reply but only MRFzones in the constant folder.
Angular velocities are also changed in the mrfzones file as well as in the U velocity file in the zero folder
In the MRFzones file it looks like this
cellRegion0
// Fixed patches (by default they 'move' with the MRF zone)
nonRotatingPatches (inlet_0 outlet_0 passageSidesUpper_0 passageSidesLower_0);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 1852.387;
In the U velocity file it looks like this
I have just put the top portion only here
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 50.0 170.0);
boundaryField
inlet_0
type temperatureDirectedInletVelocity;
inletDirection uniform (0 0 1); // Direction of absolute velocity in cartesian coordinates
phi phi; // just needed in compressible case to check dimensions
T T; // name of the static temperature field
T0 uniform 293.0; // value of the total temperature
cylindricalCS no; // specifies if inletDirection is in cartesian or cylindrical coordinates
omega (0 0 1852.387); // angular velocity
value uniform (0 0 210); // Initial Value
But still I am getting the same results (higher value of U,temperature density etc)
Infact i tried to run only laminar also but still the same result
If you have any other suggestions please tell me.
thanks
Jyothish
hi
where did you find this commands of Riemann ?are these related to riemann boundary conditions?
immortality is offline   Reply With Quote
Old   February 12, 2013, 16:49
Ehsan
hi prasant.which terms of the controlDict you mentioned i should add to my controlDict for averaging?
ok.i set T az zeroGradient but now velocity is growing very high and becomes supersonic that causes explosion in continuity and diverging occurs.
what has you done about that?
Old   February 12, 2013, 16:52
Ehsan
Im working on Wave Rotor that ia like turbochargers as I told before.could anyone send me a case of turbocharger as a good starting point?
any help or idea about this subject is appreciated.
Old   April 19, 2013, 13:50
Ehsan
which functionObjects can use to get it in output?
MassFlows: inlet_0 = 12.5882 MassFlows: outlet_0 = 9.82064
Old   April 19, 2013, 13:54
antoniofct is on a distinguished road
functions
MassFlow
type patchMassFlow;
functionObjectLibs
"libsimpleFunctionObjects.so"
verbose true;
patches
inlet_patch
outlet_patch
factor 1;// or whatever is the number of repetition
antoniofct is offline   Reply With Quote
Old   April 19, 2013, 14:03
Ehsan
thanks.
does it write mass flow rate in each time step or until that time step(total mass)?
and is there such function for total pressure?(average)
Old   April 19, 2013, 14:18
Not sure If I understood what you meant.
It writes the area-based average mass flow everytime the console outputs new values.
It can also output average pressure with the following:
areaAverage
type patchAverage;
functionObjectLibs
verbose true;
fields ( p);
patches
outlet_patch
inlet_patch
factor 1;
About total quantities, it only works if they are computed by the solver (if your solver doesn't do it, you have to implement it). When you do that, just replace the p-field with p_total.
Other option is to open paraview and use the python calculator. It is not so good but once you have a converged solution is the same..
Old   April 19, 2013, 15:00
Ehsan
thanks.I should make it in createFields.H?
do you know an example to this?
Old   April 20, 2013, 11:52
you have to create an object in createFields and then specify the solver to calculate it.
something like:
in createFields:
volScalarField ptotal
IOobject
"ptotal",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
\\put here the expression of total pressure
and then before the runtime.write() at solver.C you write
ptotal=expression of total pressure;
You probably will want to create another object for absolute Mach. To do this you will probably need another object for gamma.
immortality likes this.
Old   May 5, 2014, 04:32
dowlee is on a distinguished road
Hi jyothishkumar, i have met the same issues. I have tried a lot, but still faield. How do you solve your problem?
dowlee is offline   Reply With Quote
Old   May 26, 2014, 02:47
Post No convergence with transonicMRFDyMFOAM
  #51
sam.ho is on a distinguished road
Dear FOAMERS
I am trying to simulate radial inflow turbine passage with transonicMRFDyMFOAM. And tried with all possible temperature and pressure values but not able to get the conerged results for mass.
Please take a look at my Boundary Conditions and canstant files and suggest me how can i get the converged results.
Regards,
Sangamesh Hosur
sam.ho is offline   Reply With Quote
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Natural Convection using Compressible Flow (chtMultiRegionFOAM) msarkar OpenFOAM 2 September 7, 2010 01:13
help with compressible flow BC's (need subsonic flow) meangreen Main CFD Forum 5 July 24, 2010 14:16
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 15:05
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 14:19
