sample
Old   January 28, 2012, 10:10
Default sample
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I have a question about using the sample function in OpenFOAM. I am working on a simulator and I would like to know if it is possible to run `live' the sample command.
I mean: it at time t0 I am in the position P0, can I ask OpenFOAM to run the sample command and to return the value of the velocity in the position P0?
What I would like to do is to avoid to write a file: I'd prefer to have a variable U which contains the value of the velocity in a certain point at a certain time.
How can I do this?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   January 28, 2012, 12:20
Assistant Moderator
Bernhard Gschaider
Originally Posted by samiam1000 View Post
Dear All,
How can I do this?
Thanks a lot,
Samuele
I think what you're looking for is called "probes" and with a "functionObject" you get that written during the simulation. It should be fairly easy to find the inofrmation, now that you know the two buzz-words (I know it is hard to google such a thing if you don't know how it is called in a particular piece of software)
heat conducting in a solid domain Rogerio Fernandes Brito FLUENT 0 March 18, 2008 18:25
heat conducting in a solid domain Rogerio Fernandes Brito Fidelity CFD 0 March 18, 2008 18:24
heat conducting in a solid domain Rogerio Fernandes Brito Phoenics 0 March 18, 2008 18:23
heat conducting in a solid domain Rogerio Fernandes Brito Siemens 0 March 18, 2008 18:23
CAE program for heat conducting Rogerio Fernandes Brito FLUENT 0 February 3, 2008 12:22
