January 23, 2012, 15:11 |
(x,y,z) of cell center
ak
Rep Power: 15 |
Does anyone know how we can get (x,y,z) of cell centers in the mesh? I want to access cells whose center's x coordinate lies 10mm either side of xo = 0.05 Thank you, amit |
January 23, 2012, 17:22 |
ak
Rep Power: 15 |
i think i got it
mesh.C[celli].component(0) should work... (for x location) |
January 23, 2012, 17:40 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Yes that is true, however, if this limit is static throughout the simulation, then you should consider cellSets combined with setsToZones. This will give you access to a cellZone inside the simulation, where the cells, which fulfill your spatial requirement, are listed.
In this way you do not have to recompile your solver in case you decide to change x0 or any other parameter. Kind regards, Niels |
June 24, 2013, 16:37 |
#4 | |
Andrej
Rep Power: 13 |
does it mean, that I can control the center of cells during calculations? I want to experiment with algorithm for choosing cell centers to minimize the non-orthogonality effects. I really need it, because i've constructed a mesh with triangle prisms, with acute triangles - so using Voronoy points as cell centers would solve problems with errors because of non-orthogonality. Forcing OpenFOAM to use my custom cell centers in ALL calculations - is it possible? regards, Andrej |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
How to determine the location of the cell center | zmester | Main CFD Forum | 0 | October 11, 2009 07:58 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
About Cell Center | Harry | FLUENT | 0 | December 3, 2000 05:33 |
