OpenFOAM error message need help!!
Old   January 16, 2012, 12:23
Default OpenFOAM error message need help!!
rawe666 is on a distinguished road
Hello, I am quite new to OpenFOAM and trying to make a simulation with rhoSimplecFoam solver. I always get same error message when I run the simulation. I tried with lower time step and finer meshes but it does not work. Could someone help me with that error message? Thanks in advance !!!
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoSimplecFoam"
#6 __libc_start_main in "/lib/libc.so.6"
Gleitkomma-Ausnahme
rawe666 is offline   Reply With Quote
Old   January 16, 2012, 12:30
Pierre Castellani
pcaste12 is on a distinguished road
I am also quit new but rhoSimplecFoam works well. Did you run the tutorial squareBend?
Pierre.
pcaste12 is offline   Reply With Quote
Old   January 16, 2012, 12:38
Hi Pierre,
No I did not run squareBend tutorial. I tried rhoSimplecFoam solver for very easy geomety and it worked well. But now I have different geometry but it does not work. Did you run the squareBend it gives an error as well.
Old   January 16, 2012, 12:48
Pierre Castellani
Try the squareBend which is in 3D using high T and high speed.
On my side it work very well.
Old   January 16, 2012, 12:52
In my case I defined fixedValue condition for pressure and velocity at the inlet. I am not sure but it might be the source of my error message. Do you have any idea?
Old   January 16, 2012, 12:57
Pierre Castellani
Well, usually you could not use fixedValue for pressure and velocity at the same time for the same patch. Try to have an inletoutlet way for the velocity. Otherwise you could try to fixe the value at the outlet patch for presure (for example) if possible, of course!
error, openfoam, printstack, rhosimplecfoam
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
