Making Geometry in Gmsh
Old   January 12, 2012, 08:12
Default Making Geometry in Gmsh
Rahul Singh
rahulsng is on a distinguished road
Hello friends,
I am having problem making a simple geometry in Gmsh. I am trying to make a cylinder with a bulge. The bulge part of the cylinder is based on a 2D equation. The cylinder part is Ok but i am not able to draw the bulged part of the cylinder in Gmsh. I tried to import the Iges file from solidworks and save it as .geo file but the saved .geo has a lot of splines in it. I was thinking is there a simpler way to draw this geometry directly into Gmsh.
Thanks a lot for any help!
Rahul
rahulsng is offline   Reply With Quote
Old   January 14, 2012, 07:05
seboxx is on a distinguished road
Hello Rahul,
I have tried meshing similiar geometries in Gmsh as well. It turned out that especially the link to OF to get a proper mesh is quite tricky.
So I started using blockMesh.
I am quite happy with the way blockMesh works, the only minus is, you can't "draw" your mesh.
Cylinder and Bulge should be easy to realise in blockMesh using arcs and splines...
Just wanted to give u a recommendation
Regards,
seb
seboxx is offline   Reply With Quote
geometry., gmsh
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
