uncoupled lagrangian particle tracking
Old   January 9, 2012, 16:34
Default uncoupled lagrangian particle tracking
mikeP is on a distinguished road
Hi, I want to write a particle tracking solver with one way coupling, which is similar to solidParticleFoam.
solidParticleFoam is simple enough for me to modify the equation of motion as I want. It uses solidParticleCloud but there is also a 'kinematicCloud' in OpenFOAM libraries and this confuses me. I'd like to ask the difference between solidParticleCloud and kinematicCloud.
Could you show me where the equation of motion for kinematicCloud is written?
I noticed that in kinematicCloudProperties file you can define if you want a collision model, or if you want particles to stick to surface, or if you want dispersion, etc. But other than these models, is there any significant differences between those 2 models, considering my needs? Can I switch off 2way coupling for example?
mikeP is offline   Reply With Quote
Old   January 12, 2012, 09:22
I decided to go on with solidParticleFoam and modified it a little bit. However, my particle do not actually hit the boundary walls. They stop some distance before the boundary, even though I have changed the wallImpactDistance function to:
Foam::scalar Foam::mySolidParticle::wallImpactDistance(const vector&) const
    return 0.0*d_;
    //return 0.5*d_;
I searched the location where hitWallPatch function is called but could not find. Where is it called?
Old   September 10, 2013, 13:44
India
mayank.dce2k7 is on a distinguished road
Hi mikeP,
I am also working with solidParticleFoam. I have completed running simulation. I want to calculate number of particles escaping through outlet patch. Can you help me with that?
Regards,
Mayank.
mayank.dce2k7 is offline   Reply With Quote
Lagrangian Particle Tracking Initial step Bruce Hartley OpenFOAM Programming & Development 4 September 2, 2015 06:32
lagrangian particle tracking (LPT) to solve two phase flow mksingh OpenFOAM 0 August 22, 2011 05:09
Lagrangian Particle Tracking model In CFX Kushagra CFX 8 December 2, 2010 22:18
Lagrangian particle tracking! Guilhem O FLUENT 1 October 24, 2010 15:29
cod for lagrangian particle tracking mazdak Main CFD Forum 2 December 29, 2009 03:53
