OpenFOAM2.1.0
Old   December 20, 2011, 12:25
Default OpenFOAM2.1.0
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi dear FOAMers
I have a problem. When I want to install openFOAM2.1.0 on my UBUNTU10.04 I got this error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package openfoam210
Is any one has the same problem?
p.s. I added OpenFOAM repository to my repositories.
Best regards
ata is offline   Reply With Quote
Old   December 20, 2011, 15:36
Cyp
Cyprien
Cyp is on a distinguished road
Are you running with Ubuntu 11.10 ?
Cyp is offline   Reply With Quote
Old   December 20, 2011, 16:53
Tibor Nyers
Toorop is on a distinguished road
If you are not a "bughunter", it's generally a good idea to delay the installation of a new OpenFOAM version a couple of days after the release. It usually has some early hiccups and it takes some time to iron it out.
My note about the git install:
The link provided with the git installation guide ambiguously offers the ThirdParty-2.0.0.gtgz as the latest version. The link for the latest and greatest is ThirdParty-2.1.0.tgz.
Toorop is offline   Reply With Quote
Old   December 20, 2011, 17:15
aat
aat is on a distinguished road
Hello ata,
Tibor has a good point. However, if you would still like to install OpenFOAM 2.1.0, here's how I resolved that problem:
In my case, this was because I had installed Ubuntu 10.04 build called Maverick, while the OpenFOAM repository looks for build name Lucid (10.04 LTS). I got around this by setting VERS to lucid, and then adding the repository as indicated in step 2 (on download page at openfoam.com). After running sudo apt-get update, I was able to run sudo apt-get install successfully.
Perhaps this helps?
-Amish
aat is offline   Reply With Quote
Old   December 20, 2011, 17:30
Cyp
Cyprien
Originally Posted by aat View Post
Hello ata,
Perhaps this helps?
-Amish
It was the point I though. It works for me.
Old   December 21, 2011, 01:16
Philippose Rajan
philippose will become famous soon enough
Just wanted to report that the OpenFOAM-2.1.0 RPM installation for Fedora worked perfectly fine on my Fedora 16 64-bit system.
The only hiccup was, that OpenMPI is installed in a "non-standard" location when a standard install of OpenMPI from the Fedora repositories is done. This requires a manual addition of the following nature before sourcing the OpenFOAM "bashrc" file....:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib64/openmpi/lib
export PATH=$PATH:/usr/lib64/openmpi/bin
source <OpenFOAM bashrc file>
Philippose
philippose is offline   Reply With Quote
Old   December 21, 2011, 04:43
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
'module load openmpi-$arch' is better, as stated in the instructions, but I'll make it clearer.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
