November 29, 2011, 08:33 |
gmshToFoam teminates on Segmentation fault
Rep Power: 14 |
I created a .msh file with gmsh 2.4.2 on Ubuntu Linux. Now I want to convert it to OpenFoam201. I copied the mesh to the OpenFoam example folder $FOAM_RUN/tutorials/incompressible/icoFoam/cavity/ . There I executed "gmshToFoam ./Savonius_S2.geo.msh". It terminates on a Segmentation fault (I shortened some long output):
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : gmshToFoam ./Savonius_S2.geo.msh Date : Nov 29 2011 Host : ubuntu PID : 8927 Case : /home/hanke/OpenFOAM/hanke-2.0.1/run/tutorials/incompressible/icoFoam/Savonius nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Starting to read mesh format at line 2 Read format version 2.1 ascii 0 Starting to read points at line 5 Vertices to be read:175 Vertices read:175 Starting to read cells at line 183 Cells to be read:1333 Unhandled element 15 at line 185 ... Unhandled element 15 at line 209 Unhandled element 1 at line 210 ... Unhandled element 1 at line 305 Mapping region 0 to Foam patch 0 Mapping region 0 to Foam cellZone 0 Cells: total:876 hex :0 prism:0 pyr :0 tet :876 CellZones: Zone Size 0 876 Skipping tag at line 1519 Patch 0 gets name patch0 Finding faces of patch 0 --> FOAM Warning : Not using gmsh face 3(27 25 7) since zero vertex is not on boundary of polyMesh ... --> FOAM Warning : Not using gmsh face 3(22 35 38) since zero vertex is not on boundary of polyMesh FaceZones: Zone Size 0 336 Writing zone 0 to cellZone cellZone_0 and cellSet Writing zone 0 to faceZone faceZone_0 and faceSet #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/gmshToFoam" #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/gmshToFoam" Segmentation fault |
November 30, 2011, 02:50 |
Maxime Perelli
Rep Power: 41 |
you are not in the right forum >>>> http://www.cfd-online.com/Forums/ope...meshing-other/
With which software did you create your .msh file?
In memory of my friend Hervé: CFD engineer & freerider |
November 30, 2011, 04:22 |
Rep Power: 14 |
As stated out in the first post I created the mesh with gmsh 2.4.2.
Perhaps one of the admins could be so kind to move this thread to the correct location? |
December 2, 2011, 03:02 |
Rep Power: 14 |
Can anybody confirm that the mesh itself and not my installation of OpenFOAM causes the fault?
December 2, 2011, 03:47 |
Rep Power: 14 |
In http://www.cfd-online.com/Forums/ope...ion-error.html a similar problem has been described. It seems as if it could be solved by removing the "gmsh label". Unfortunately I have not idea what this means. Anyone else?
December 3, 2011, 04:25 |
Rep Power: 14 |
I tried a mesh from an new smaller and simpler geometry (attached to this post). The output of the mesh conversion is now:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : gmshToFoam Cylinder.msh Date : Dec 03 2011 Time : 10:07:35 Host : ubuntu PID : 2222 Case : /home/hanke/OpenFOAM/hanke-2.0.1/run/tutorials/incompressible/icoFoam/Cylinder nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Starting to read mesh format at line 2 Read format version 2.1 ascii 0 Starting to read points at line 5 Vertices to be read:1232 Vertices read:1232 Starting to read cells at line 1240 Cells to be read:6835 Unhandled element 15 at line 1242 ... Unhandled element 1 at line 1367 Mapping region 0 to Foam patch 0 Mapping region 0 to Foam cellZone 0 Cells: total:5303 hex :0 prism:0 pyr :0 tet :5303 CellZones: Zone Size 0 5303 Skipping tag at line 8078 Patch 0 gets name patch0 --> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 614 Found 1406 undefined faces in mesh; adding to default patch. Finding faces of patch 0 FaceZones: Zone Size Writing zone 0 to cellZone cellZone_0 and cellSet End Are the unhandled elements bad? Does the conversion work now because the geometry is smaller or simpler (I used a copy of the incompressible/icofoam/cavity example as starting point)? Which tutorial should I copy to convert the mesh from my initial Post? When I directly launch "icoFoam" after conversion, I get the following error message: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : icoFoam Date : Dec 03 2011 Time : 10:19:02 Host : ubuntu PID : 2642 Case : /home/.../run/tutorials/incompressible/icoFoam/Cylinder nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p --> FOAM FATAL IO ERROR: keyword patch0 is undefined in dictionary "/home/.../run/tutorials/incompressible/icoFoam/Cylinder/0/p::boundaryField" file: /home/.../run/tutorials/incompressible/icoFoam/Cylinder/0/p::boundaryField from line 25 to line 35. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 461. FOAM exiting Is there something else I have to do before launching "icoFoam"? Does the cavity tutorial simply not fit to my mesh? Last edited by XXLRay; December 3, 2011 at 11:41. |
December 5, 2011, 03:21 |
Rep Power: 14 |
Do you need any more information to help me? Just ask and I will provide it.
I expect it to be an effort of a few minutes for someone experienced to try my mesh. Finding a solution on my own yet took me weeks and will take me months. Any help is really appreciated. |
December 6, 2011, 03:45 |
Rep Power: 14 |
Is anybody out there?
December 6, 2011, 09:36 |
#9 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings XXLRay,
I personally don't have time to test the mesh, but this should be self explanatory in one of your latter posts: Code:
keyword patch0 is undefined in dictionary "/home/.../run/tutorials/incompressible/icoFoam/Cylinder/0/p::boundaryField" I suggest that you review the first tutorial (or even all 3 tutorials) on the User Guide to remember about boundaries and patches: http://www.openfoam.com/docs/user/cavity.php#x5-40002.1 As for «removing the "gmsh label"», the ".gmsh" files can sometimes be in text format, so editing the mesh ".gmsh" file with a text editor might be the way to go! Best regards and good luck! Bruno
December 7, 2011, 02:10 |
#10 |
Rep Power: 14 |
Thanks a lot. I will try that.
[OpenFOAM] Paraview - Segmentation fault | grjmell | ParaView | 5 | January 9, 2024 13:14 |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 21:59 |
Segmentation Fault | Shawn_A | OpenFOAM Running, Solving & CFD | 6 | October 31, 2011 14:38 |
ParaView segmentation fault only for multiphase | gwierink | OpenFOAM | 9 | March 25, 2010 07:23 |
