November 25, 2011, 01:34 |
Foil Bearing Simulation
Balaji Sankar
Rep Power: 14 |
Hi all,
I have to simulate the orbit(path taken by the centre ) of the shaft in a foil bearing with air as the lubricant instead of oil. The foil bearing is same as the Journal bearing except that the boundary is deformable and not rigid like a journal bearing. There is a pressure build up because shaft is rotating and dragging the air around it into a narrow channel.(See image) I obviously need to solve the a) Pressure build up in the fluid b) Deformation of the boundary due to the built up pressure. c) Motion of the shaft centre inside the bearing in response to the pressure and its own rotation. Hope I am clear. 1) Has anyone solved this in OpenFOAM before.? 2) what are the solvers I should read up on? Any pointers to start or links to similar solved problems will be very usefull. |
November 25, 2011, 03:32 |
maybe http://powerlab.fsb.hr/ped/kturbo/Op...dicPhD2005.pdf Doctorate Thesis: Advanced Modelling of Elastohydrodynamic Lubrication by Petra Brajdic-Mitidieri http://powerlab.fsb.hr/ped/kturbo/Op...riImperial.pdf is something for you |
November 28, 2011, 03:20 |
Balaji Sankar
Rep Power: 14 |
Thanks Elvis.
I will see what Brajdic has done in his Thesis. |
May 1, 2013, 09:20 |
Help
Fabian
Rep Power: 13 |
Bajji, could you finally model the bearing?, I need to do the same and if you can help me, with something like with solver did you use (rhoSimplecFoam, rhoCentral foam) or more datails I will be very helpull.
May 1, 2013, 23:47 |
Couldn't do it in openFOAM.
Balaji Sankar
Rep Power: 14 |
Hi fpierart,
I did finally model the bearing with shaft motion inside it. But I gave up on openFOAM and wrote the Reynold's equation solver (I tried FDM and FVM) in C++ from scratch. It worked. I got pretty good agreements between simulated and published pressure distributions at mid plane. I want to make clear that it was not a problem with openFOAM. I simply couldn't get that monster working. Have great time, Balaji Sankar. |
bearings, fsi, openfoam, shaft dynamics |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
problem is modeling and simulation of an air foil | alnabhani | CFX | 4 | December 2, 2010 13:24 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 08:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 18:57 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
