November 24, 2011, 02:15 |
Writing Averaged Data into a Text File.
Pang
Rep Power: 15 |
Good day to all!
I'm a beginner to OpenFOAM. I'm using OpenFOAM 2.0.1 and now learning OpenFOAM with the dieselFoam tutorial. I'm trying to write the domain averaged data on an output text file but I couldn't get it out. Let's say for instance I try to extract the averaged pressure, I added ================================================== =================== functions ( pAverage { functionObjectLibs ("libutilityFunctionObjects.so"); type coded; redirectType average; outputControl outputTime; code #{ const volScalarField& p = mesh().lookupObject<volScalarField>("p"); Info<<"p avg:" << average(p) << endl; #}; } ); ================================================== =================== into the controlDict file. It's supposed to at least write the average pressure to the terminal if I'm not mistaken but I didn't observe anything. Can you please kindly advise that how can I solve the problem? Thank you very much in advance. Best regards, Kar. |
November 24, 2011, 14:27 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
November 25, 2011, 22:46 |
Pang
Rep Power: 15 |
Thank you Bernhard for the information. I shall try again to figure it out. =)
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
Problems With Journal When Writing Forces To File | Andrew | FLUENT | 2 | September 23, 2005 02:12 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
