November 15, 2011, 07:26 |
Cp for low temperatures
Disabled
Rep Power: 15 |
Does anybody know what is the equivalent of the Janaf model
for low temperatures (e.g. 30K-600K)? I have not been able to find a solution to this and my OpenFOAM numerical simulation keeps diverging. |
November 15, 2011, 09:43 |
#2 | |
Disabled
Rep Power: 15 |
OK, I need to provide more information for my run case.
A figure of the axisymmetric geometry I am trying to solve is attached, with the initial conditions in pressure. We have atmospheric pressure on the left and very low pressure on the right (my Knudsen is in the limits of the applicability of hydrodynamic equations). The solver I use is rhoCentralFoam and the flow is time-dependent. There are walls everywhere around (besides the symmetry axis), therefore the boundary conditions can not be causing a problem. As far as the mesh is concerned, I have used a variety of discretizations. The checkMesh report for the latest one is shown below: Quote:
In an early stage of the simulation (especially if the outlet pressure is 250Pa instead of 2500Pa), the temperature drops significantly, overcoming the limit of applicability for the Janaf tables. It certainly seems realistic (to me) that the temperature drops below 100K in this case. So, I guess the only thing left is the thermodynamic properties. Could someone verify at least if I have checked every possibility? Is there a relatively easy way to incorporate low temperature data in OpenFOAM? |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Non-steady flow simplified for use in Vissim | steamerandy | Main CFD Forum | 0 | October 31, 2011 21:08 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
What is the difference between liquid reactive flow and gas reactive flow? | James | Main CFD Forum | 6 | May 15, 2009 12:14 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
