November 8, 2011, 12:57 |
buoyantSimpleFoam abort error
Rep Power: 17 |
Good Evening Everybody,
I am trying to simulate the flow over a hot board to investigate the boundary layer of velocity and temperature. I have already done a simulation with rhoSimpleFoam. Now I want to start a simultion with buoyantSimpleFoam. Iīve made the setup and OpenFoam told me to initialize with potentialFoam. Iīve initialized with my rhoSimpleFoam solution. Now the simulation starts but then it aborts after few iterations giving me this strange error massage: Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #8 Foam::fvMatrix<double>::solve() in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" #9 in "/home/camoesas/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam" #10 __libc_start_main in "/lib64/libc.so.6" #11 at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116 thanks
OF - 2.0.0 |
November 9, 2011, 04:20 |
Rep Power: 17 |
HI Nima,
thanks for the hint. But it just makes my solver slower and its still aborting at the same step. As one can see the residuals are exploding.
OF - 2.0.0 |
November 16, 2011, 04:46 |
Rep Power: 17 |
Iīve got it running but in the end I donīt know what exactly was the important change. Therefore I am uploading the whole case as example and inspiration for everybody who is struggling with buoyantSimpleFoam.
OF - 2.0.0 |
November 16, 2011, 04:47 |
Rep Power: 17 |
OF - 2.0.0 Last edited by camoesas; November 16, 2011 at 05:11. |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
