converting tetgenToFoam
Old   November 7, 2011, 12:54
Default converting tetgenToFoam
vahid
vahid_paris is on a distinguished road
Hi everybody,
I want to convert .stl (test.stl) file to openFoam. First, I used tetgen to convert .stl file to (.ele, .face, .node and .smesh) with the common order:
./tetgen test.stl
And then, I used the following command to convert tetgen files (test.1.ele, test.1.node, test.1.face and test.1.smesh) to Foam:
tetgenToFoam test.1
But, and I have the following error:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 2.0.1-51f1de99a4bc
Exec : tetgenToFoam test.1
Date : Nov 07 2011
Time : 17:29:05
Host : ST2016X
PID : 21807
Case : /home/simuser/TEST/tutorials/incompressible/channelFoam/channel395
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Files:
nodes : "test.1.node"
elems : "test.1.ele"
faces : "test.1.face"
Reading .face file for boundary information
--> FOAM FATAL ERROR:
Cannot read "test.1.node" or "test.1.ele"
From function tetgenToFoam
in file tetgenToFoam.C at line 136.
FOAM exiting
any idea?
Actually, I used an example in the tutorial and I just replaced blockMeshDict file in polyMesh folder with test.stl file (wich has a different geometry). I just wanted to check the mesh conversion (from .stl to openFoam). Should I change any other files in channel395 folder?
Thanks
vahid_paris is offline   Reply With Quote
Old   December 4, 2012, 12:42
Deutschland
Flexwars is on a distinguished road
Hey Vahid,
i have the exact same problem. Did you find a solution yet?
Hopfully, its quite a long time ago
Thx
Felix
Flexwars is offline   Reply With Quote
Fluent converting 'wall' to 'interior' BC for hybrid mesh DarrenC FLUENT 8 January 3, 2019 07:24
[Commercial meshers] problem in converting mesh from fluent kiran OpenFOAM Meshing & Mesh Conversion 1 November 2, 2010 17:25
converting user-coding in V4 Karl Mehler Siemens 0 September 28, 2008 16:48
TetgenToFoam karen OpenFOAM Bugs 2 August 6, 2008 12:27
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 16:08
