fan coefficients
Old   November 7, 2011, 05:17
Default fan coefficients
supercommandodhruv
dhruv is on a distinguished road
Hello all,
I am trying to simulate a fan in an open channel with a radiator in front of the fan, modeled as a porous zone. The flow in the channel is entirely driven by the fan. I am using the fan boundary condition. My mesh is made of almost 3 million cells.
Some details are as follows:
p (inlet and outlet)
type totalPressure;
U (inlet)
type pressureInletOutletVelocity;
value uniform (0 0 0);
U (outlet)
type inletOutlet;
inletValue uniform (0 0 0);
solver: porousSimpleFoam
The pressure curve of fan is taken as linear for simplicity, with 2 coefficients in the f List<scalar>. the equation is of the form delP = a - bx, where x is the velocity.
My observations are that as I change the coefficients of the fan in the same geometry, my calculations take longer and longer to converge. So, if I take the first coefficient (value of "a" in the fan equation above) as (say) 500, my solution converges in 6000 steps, but if I increase the value of the coefficient to 800, the solution takes almost 9000 steps to converge. So, it takes very long time to reach the duty point of the fan.
I do not understand why this happens . Can anyone help me with this?
Regards,
Dhruv.
dhruv is offline   Reply With Quote
Old   November 8, 2011, 05:44
Eugene de Villiers
eugene is on a distinguished road
Dhruv,
I might be wrong here, but the probable reason this thing takes so long to converge is because your fan has to accelerate the flow from a stationary starting point. The faster the fan turns, the more the flow has to be accelerated before it reaches equilibrium, leading to longer integration times.
Try starting with a initial velocity field closer to the final one and see if this improves matters.
Eugene
eugene is offline   Reply With Quote
Old   December 8, 2011, 07:10
Default Thanks... but a different approach worked.
supercommandodhruv
Hi Eugene,
Thanks for the reply. I did get a faster convergence to one of my problems, but not in some cases. But I would like to point out that the problem was the explicit and implicit solution method applied to porousZones. When I changed my fvSolution file to implicit from explicit, my problem reached convergence in 2500 steps (rather that 9000-10000 steps in explicit), and also was much more stable and accurate.
Do you know, why is there so much of a difference between these two solution methods?
Regards,
Dhruv.
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 05:54
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Momentum Source for fan TX_Air CFX 5 September 29, 2010 19:42
Proper BCs for internal fan serezhkin CFX 3 July 28, 2010 11:04
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 20:37
