luca
Rep Power: 15 ![]() |
hi everybody
I need to solve the flow over a sloping bed in a 3D mesh. I therefore need the cells at the boundary wall to be as rectangular as possible. when i generate the mesh i obtain only vertical lines in my depth direction and this results in a highly skewed mesh. how can i tell the program that i want all the angles of the cell to be as perpendicular as possible? Is there any command in gmsh that can do this? thanks |
Gregor Seljak
Can you attach your .geo file, so we can see the exact geometry. Then it will be easier to give some advice.
luca
thanks
i attached the file. as you can see I have a highly skewed mesh. and i want to have the cells at the bottom boundary layer to be rectangular and not rhomboid. is there any algorithm i can use?? |
Gregor Seljak
I don't know if I understand you correctly, but if you use Recombine Surface, you get mesh like this
luca
Thanks.
I explained myself badly... sorry! Lets try to explain it with a picture. You can find that attached. The vertical direction in the figure represents the z axis. As you can see my actual mesh(left) has the boundary cells rhomboid shaped at the bottom (i am simulating a boundary layer flow so i need cells to be rectangular) I want to have them as rectangular as possible like in the sketch i made (right). I now did Recombine Mesh and my mesh is now uploaded (attached). |
gmsh, mesh |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
