How can I read the results?
Old   October 26, 2011, 05:57
Default How can I read the results?
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I did the simulation of a certain area.
Once I got the result, I got some files with a huge list of numbers. How can I link this numbers to the position?
I mean: I would like to know velocity in the x, y, z point of my domain. Which is the right line in the U file that I have as output?
Could you help?
Thanks,
Samuele
samiam1000 is offline   Reply With Quote
Old   October 26, 2011, 06:22
Nima Samkhaniani
nimasam is on a distinguished road
open it with paraview use:
filter > intergateVariable
nimasam is offline   Reply With Quote
Old   October 26, 2011, 06:24
Samuele Z
I will try.
Also, if I wanna view the results on a PC where OpenFOAM is not installed (but Paraview is), what should I do?
When I try to open the output text files (let's say U), I can see anything!
Old   October 26, 2011, 06:37
Nima Samkhaniani
you have several choices for example
1) copy all result data on the second PC
2) use foamToVTK then only transfer vtk files
Old   October 26, 2011, 06:39
Samuele Z
I give the command foamToVTK in the case folder, right?
Thanks a lot,
Samuele
Old   November 7, 2011, 14:19
Samuele Z
Actually,
I am trying to find the value of U in each point of my grid. If I am not wrong there is a relationship between the file with the points and the file with the results.
The question is: which is this relationship? I would like to write a short script which:
- read a certain point (i.e. x0, y0, z0) in the points file
- link this point with the closest cell
- enter in the U file with the label of the cell and read the velocity in that point
Do you think it's a reasonable idea?
Thanks a lot,
Samuele
Old   November 7, 2011, 15:32
Nima Samkhaniani
hi dear samual
i dont know you are looking for what?
if you want cell centroid position you can easily do
with mesh.C()
if you just want to see the value of u i suggest easier above!
whats ur means by "link this point with the closest cell"?
your post is totally vague for me
Old   November 14, 2011, 05:09
Samuele Z
Dear Nimasam,
let me write a more detailed post: I have a domain with 5 flat faces and the bottom face is the terrain-profile of a certain region. Let's say that the boundaries of my domain are: x = 0, 100; y = 0, 100; z = 0, 30.
I perform my simulation. And I have a file U with the results.
Now I want to know the vector U in the point P (20, 20, 5).
What should I do? Which is the link between the file U and the file containing the points?
I hope this explains better my goals.
Thanks a lot,
Samuele
Old   November 14, 2011, 07:53
Bernhard
Bernhard is on a distinguished road
This information is interwoven with the files in the constant/polyMesh directory. If you're interested in this specific point, I advise you to use the sample utility.
Bernhard is offline   Reply With Quote
Old   November 14, 2011, 07:56
Samuele Z
Actually,
I need all the points.. That's why I am interested in the `link' between the U file and the points file.
Could you explicit it?
Thanks! Samuele
Old   November 14, 2011, 08:03
Bernhard
Normally you don't want that info. You can read the files with the openfoam-reader for Paraview, or you can use any of the convertors to other post-processing tools. What is it exactly what you want?
More about the polyMesh can be found here: http://www.openfoam.com/docs/user/mesh-description.php
However, I am quite sure this is not what you want to dig in to, since all the utilities are already available.
Old   November 15, 2011, 07:07
Samuele Z
Dear Bernhard,
thanks to you, too, for answering.
Let me try to explain what I wanna do: I wanna have a matrix which correlates the results that I get from my simulation with their x, y, z coordinates. Thus, I can insert this results in a software for a simulator which allows me to recreate the ``real'' conditions depending on the velocity of the asymptotic wind.
Do you think there is a smarter way to do that?
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Reading CFX-CFD results without Ansys CFX JAY ANSYS 2 July 7, 2009 17:48
LES of highly heated pipe flow - incorrect results MichalH FLUENT 3 June 3, 2009 06:00
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
Airfoil y+ Results Query asd Main CFD Forum 1 June 22, 2007 09:02
