labelListList handling
Like Tree1Likes
Old   May 20, 2014, 07:14
Tomislav Maric
tomislav_maric is on a distinguished road
@Daniel:
Because when i write : "const labelListList & listlist; " i get the error because of non-initialization.
You are trying to bind a const reference to nothing. References are aliases to objects, put most simply. Se this SO answer for information on the differences between pointers and references.
If you need an empty object, do this:
    labelListList listlist;
If you are going to use the listlist in the constructor and zero-initialize it, it makes no sense to declare it const. The member functions will not be able to modify the zero-initialized listlist. So, just use the listlist as a regular object as in the code snippet above.
If you need a dynamic list of label lists, using the DynamicList template with default template arguments for container expansion, it looks like this:
    // Shorten the type name. Note the space between the last '> >' -
    // unless you are using the C++11 standad.
    typedef DynamicList<DynamicList<label> > dynamicLabelListList;
    // Use your new type name alias and declare an empty list object.
    dynamicLabelListList listList;
    // append a label
    listList.append(0);
Note that even though the dynamic list is dynamic the cost of expansion is still slightly better than O(n) (because of a default expansion strategy that reserves extra capacity). If you are using the list to store 100 labels, you won't see the difference. With 1e06 labels you will, and you should initialize the list with a reasonable starting size.
Good luck, hope this helps.T
Daniel73 likes this.
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   May 20, 2014, 09:20
Daniel73 is on a distinguished road
Many Thanks
Daniel73 is offline   Reply With Quote
Problem with handling LES modeling with dynamic mesh g.akbari OpenFOAM Running, Solving & CFD 0 March 8, 2010 17:18
Error%7eerror triggers crash after handling exceptions thrown by errorexit twice 7islands OpenFOAM Bugs 2 September 4, 2007 06:24
Handling axisymmetry terms on the symmetry line Sonny Main CFD Forum 4 December 9, 2005 17:22
macros handling vectors sivakumar FLUENT 0 January 18, 2002 17:16
