Rep Power: 15 ![]() |
Hello everyone,
I would like to merge two meshes I built separately with gsmh, on a surface in my geometry that I named 'interface' (the same name) for both the parts. I am not that familiar with the corresponding utilities in OpenFoam (I was wondering to use stitchMesh, rather than MergeMesh in order to get a unique full geometry where the 'interface' patch will result to be internal), so please, is there anyone that could drive me step by step (with the command lines, I mean) for doing that, from the starting point with converting the two separate meshes obtained with gmsh? |
mergemesh, stitchmesh |
[mesh manipulation] stitchMesh | dhruv | OpenFOAM Meshing & Mesh Conversion | 13 | February 23, 2012 17:14 |
[mesh manipulation] stitchMesh and mergeMeshes removal of interfaces | flowris | OpenFOAM Meshing & Mesh Conversion | 6 | July 16, 2010 12:06 |
[blockMesh] mergePatchPairs vs stitchMesh | pg22 | OpenFOAM Meshing & Mesh Conversion | 1 | March 10, 2010 05:50 |
Change in triangle::intersection breaks stitchMesh in 1.5 and 1.6 | gschaider | OpenFOAM Bugs | 7 | February 12, 2010 09:21 |
stitchMesh for uncongruent patches (stitch tolerance) | beugold | OpenFOAM | 0 | June 18, 2009 07:38 |
