October 17, 2011, 15:53 |
Shocktube in OpenFoam
Alexander
Rep Power: 15 |
Hi
I am having problems with the shocktube tutorial. There is in my interest to specify conditions on both sides on the Diaphragm, and henceforth run it. I am not experienced in OpenFoam and hence not good at interpreting error messages. The following error message appear when i was running the tutorial: Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>> --> FOAM FATAL IO ERROR: keyword sides is undefined in dictionary "/home/user/OpenFOAM/user-1.7.1/run/tutorials01/compressible/rhoCentralFoam/shockTube/0/p::boundaryField" file: /home/user/OpenFOAM/user-1.7.1/run/tutorials01/compressible/rhoCentralFoam/shockTube/0/p::boundaryField from line 24 to line 30. From function dictionary::subDict(const word& keyword) const in file db/dictionary/dictionary.C at line 456. FOAM exiting I can see that i have some problems in the "0" directory, pressure file, from line 24 to 30. My initial presseure file looks like this: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0 0 0; boundaryField { inlet { type fixedValue; value uniform 10 0 0 } empty { type empty; } } // ************************************************** *********************** // I do not understand why my "sides" are "undefined". Could someone please help me ? Alex |
October 23, 2011, 17:20 |
Alexander
Rep Power: 15 |
Hi
I know now what is my problem. And as simply as it sounds: I did not execute the setFields file. Now i am running my case as the original shocktube tutorial without any changes. However, when i am executing setFields, i am only geeting the error message: wrong number of arguments, expect 0 found 2. Can someone please tell me what is wrong and how i can get this tutorial to run properly ? I really want to know how i can make this work. Alex |
October 24, 2011, 10:23 |
Hi Alexander,
maybe I can shed some light onto the problem. - The first problem simply comes from the "sides" not being defined within the initial pressure file while they are defined within your basic blockMeshDict (or another geometry dictionary). I guess some changeDict or something with a similar name does add these definitions/initial values. At least I would get this error-message everytime I forget to specify a boundary within my initial setup-files. ;-) - Concerning the setFields-problem: Could you please specify what options you use for that (just copy-paste the command you use to this thread)? I do not remember the correct use of it by heart, but usually that happens if you try to tell setFields too much, like having non-usable parameters while executing it... |
October 24, 2011, 12:53 |
Alexander
Rep Power: 15 |
Hi Bernhard, thanks for your reply.
this is how my setFieldsDict file looks like: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volVectorFieldValue U ( 0 0 0 ) volScalarFieldValue T 348.432 volScalarFieldValue p 100000 ); regions ( boxToCell { box ( 0 -1 -1 ) ( 5 1 1 ) ; fieldValues ( volScalarFieldValue T 278.746 volScalarFieldValue p 10000 ) ; } ); // ************************************************** *********************** // This is by the way the original setFieldsDict file, without any changes. Alex |
January 2, 2013, 10:47 |
Regarding Setfieldfile
Himanshu Sharma
Rep Power: 14 |
hi Alex,
i Just want to Know how do u excuted set field for to debug the error i am also trying to run the tutorial but is giving me the error as shown below I am new to open Foam if you can put some views on it... vaio@ubuntu:~/OpenFOAM/vaio-2.1.1/run/shockTube$ rhoCentralFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : rhoCentralFoam Date : Jan 02 2013 Time : 20:14:57 Host : "ubuntu" PID : 28170 Case : /home/vaio/OpenFOAM/vaio-2.1.1/run/shockTube nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> Reading field U Creating turbulence model Selecting turbulence model type laminar Reading thermophysicalProperties fluxScheme: Kurganov Starting time loop #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 void Foam::divide<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::Vect or<double>, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam" #4 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator/<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<Foam::Vect or<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam" #5 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/rhoCentralFoam" Floating point exception (core dumped) Thanks |
January 5, 2013, 10:03 |
Alexander
Rep Power: 15 |
Hi, could you please post your setfield file for me so i can have a look at it?
Alex |
January 5, 2013, 11:02 |
#7 | |
A.R.Sangtabi
Rep Power: 14 |
please run this tutorial with ./Allrun if you dont have any error,look at in tutorial's file to found your problem shockTube.zip |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
