bojiezhang
Rep Power: 16 ![]() |
hello everyFoamer:
I have two problems, and hope someone can help me, 1:when I use the function below: Foam::cos( -omega*runTime.value()) the dimension of omega is[0,0,-1,0,0,0,0], It can compile pretty well, but when caculating, the error comes as below: ds not dimensionless From function cos(const dimensionedScalar& ds) 2:when I assign the value as below: mass[cellI] =A*omega*Foam::cos(-omega*runTime.value()); mass is volScalarField , and intialized as dimensionedScalar("zero", dimensionSet(0,1,-1,0,0,0,0), 0.0) the dimension of A is [0,1,0,0,0,0,0],the dimension of omega is[0,0,-1,0,0,0,0], when compiled , it shows "error":can not convert dimensioned<double> to double ; what can I do , I really hope someone can give me some advice, thank you in advance! bojiezhang |
Nima Samkhaniani
Rep Power: 24 ![]() |
1) define omega as dimless , because when u use the value() function, it only returns the value of run time not its dimension!
2) its not important whats the dimension of volScalarField is, when you use just on array of it! its a scalar with out dimension so the left side should be dimensionless too, but ur left side is not dimension less, its an strange combination of [0 0 1 0 0 0 0]* cos [0 0 -1 0 0 0 0] for compiler, so define A as dimless too then congratulation ![]() |
#3 | |
bojiezhang
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
