Acceleration and pressure on bodies dropped from height into water |
October 10, 2011, 16:54 |
Kay J. Steen
Hello there, for the purpose of evaluation I hope somebody will give me some feedback on the suitability of OpenFOAM for the following type of calculations :
I am currently evaluating OpenFoam to check the possibility of using it for the following purpose: The case consists of a solid body which are lowered into water. The body could be lowered by a wire, or dropped from a given height. I will need a 6 dof solver with the possibility to constrain the body with a moving spring to simulate the flexibility of the wire. The spring should have high stiffness in tension and low stiffness in compression, (wire functionality). I will also need a wave generator that is able to set up a 5th order Navier Stoke wave as a initial condition. Desired results are acceleration and pressure on the solid body. Is this possible to perform with OpenFoam? Any feedback on this is appreciated. |
October 17, 2011, 08:41 |
Peter Maday
Rep Power: 15 |
Hello
I have no experience with such problems but the following link may give you some hints for the problem: http://dhastha.wordpress.com/2011/06...oam-pythonflu/ Peter |
October 18, 2011, 02:22 |
Kay J. Steen
Thank you, a step in the right direction.
Kay |
body drop in water |
Static vs Total Pressure | Alfonso Ferrandez | FLUENT | 2 | May 23, 2000 09:53 |
