October 10, 2011, 14:32 |
Restarting OpenFoam run
Ashish
Rep Power: 15 |
I am solving an airfoil case for different angles of attack using simpleFoam. I have results for AOA 2deg. I want to solve for an AOA 4deg with results from 2deg as initial values. How can I do that? |
October 10, 2011, 16:40 |
Daniel P. Combest
try using the mapFields utility between the two cases if they have the same boundary condition names. If the mesh is a different shape (i.e. geometrically non-similar) then I'm not sure how it interpolates to the new mesh and if it can even be used. Its worth a try.
to find the usage, try Code:
mapFields -help OpenFOAM/OpenFOAM-2.0.x/applications/utilities/preProcessing/mapFields folder. cheers, |
convergence logs of an OpenFOAM run | Alexvader | OpenFOAM | 2 | October 4, 2011 16:12 |
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev | OFU | OpenFOAM Meshing & Mesh Conversion | 0 | June 16, 2010 05:36 |
How to run Openfoam in a cluster after I install it | xiuying | OpenFOAM Installation | 5 | May 5, 2008 13:54 |
OpenFOAM 13 and LAM | msrinath80 | OpenFOAM Running, Solving & CFD | 0 | December 23, 2006 19:55 |
Run FOAM on a remote machine | luckyluke | OpenFOAM Installation | 1 | June 21, 2005 06:19 |
