October 8, 2011, 19:03 |
Linear Solver
Rep Power: 16 |
Assuming one linear system AX=B, where A is a matrix of NxN and B is a vector, A and B are known and vector X is unknown. How to use the linear solver in OpenFoam to solve this linear system?
October 8, 2011, 20:28 |
Rep Power: 16 |
I thought that two fields of X and B are probably created first as
Info<< "Reading field T\n" <<endl; volScalarField X ( IOobject ( "X", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); while I don't know how to set up B since it is known. Another question is how to set an equation to solve fvScalarMatrix XEqn ( A(X) ???? ); XEqn.solve(); If this step is properly handled, it could be easy to set up linear solver and preconditioner in fvSolution Any idea on this problem? |
October 8, 2011, 21:36 |
Santiago Marquez Damian
Rep Power: 24 |
Argen, X and B creating is just as you showed in the post. Respect the matrix, as far as I know the problem is that fvMatrices in FOAM are ever related to a geometrical problem and its discretization, so that is not possible to create them only from their coefficients and positions in the matrix (Both fvMatrix and lduMatrix don't have constructors from elements and positions). It requires to use the lduAddressing at low level and would require to code your own classes to do so.
Please FOAMers correct me if I'm wrong. Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
October 10, 2011, 01:17 |
#4 | |
Rep Power: 16 |
Do you have more suggestions on it? |
Dealing with BC's in OF 1.6 | vkrastev | OpenFOAM Running, Solving & CFD | 5 | September 4, 2012 11:58 |
ERROR #004100018; Fatal overflow in linear solver | Attila | CFX | 1 | April 13, 2012 22:22 |
What's the difference between a linear and a nonlinear solver? | bearcat | Main CFD Forum | 1 | February 5, 2010 07:11 |
free C code for large sparse matrix linear solver | ztdep | Main CFD Forum | 7 | May 24, 2007 14:14 |
linear solver failure when using SST model | fanzhong Meng | CFX | 4 | March 21, 2006 20:16 |
