No shock in airfoil 0012 case despite of Mach number exceeds 1
Like Tree4Likes
Old   October 12, 2011, 11:44
schwermetall is on a distinguished road
Hi guys
I now changed the boundary conditions for velocity at the outlet to
type inletOutlet
inletValue (0 0 0)
and pressure at the outlet to
waveTransmissive with lInf 2
Doesn't seem to change anything.
I'm now trying somthing completly different. I'm using this MUSCL scheme for divSchemes. Does any of you has experience with it ?
From what I understand this schemes tries to keep fluctuations as low as possible. Which is exactly my problem. Any experience with that ??
schwermetall is offline   Reply With Quote
Old   October 12, 2011, 12:07
Vesselin Krastev
vkrastev is on a distinguished road
Originally Posted by schwermetall View Post
Hi guys
type inletOutlet
inletValue (0 0 0)
If you have already tried upwind (and you did, right?), this was the most stable choice you can make about divSchemes. Why don't you try instead with a different turbulence model (for instance, the Spalart-Allmaras one)? Another possibility would be to resolve the boundary layer with a low-Re model, but this would increase a lot the computational time. Finally, you should also consider that the flow could be instable in nature or that it would require a long time to reach a steady-state condition.
Best
V.
vkrastev is offline   Reply With Quote
Old   October 12, 2011, 12:22
Hi vkrastev,
first of all many thanks for staying with me and my problem.
Yes I tried upwind, but not for div(tauMC). I'm now trying MUSCL 0.9 for div(phi,omega) and div(phi,k).
As it takes Ages to make a run, I haven't done major changes like changing the turbulence model today, but I'll let it run over night and report tomorrow.
This is also the reason why resolving boundary layer is no option for me. To get a physical time of 0.2 seconds, my computer is running for nearly 1.5 days. My target is to get an airfoil polar in the end (like Cl over alpha, Cd over Cl ...). So if the computation time increases further for each angle of attack I have to stop there.
Old   October 12, 2011, 13:53
Vesselin Krastev
Hi vkrastev,
No problem, I'm interested in the performances of rhoCentralFoam too (though my case is quite different from yours).
div(tauMC) is not a convective term, but an explicitly calculated divergence term, so I don't think it could make some difference in the stability of the calculations (actually I'm not even sure it could be calculated in other ways than linear interpolation, as in this case there's no convection velocity involved and thus the concept of "upwind direction" becomes meaningless). Instead, div(phi,<something>) are convective terms, which are always source of stability issues (and in my experience this is especially true for convective terms involving turbulent quantities): so, if you have already tried the upwind scheme on them, then you cannot do anything more about their stability behavior.
I understand. In this case you can change the turbulence model retaining the wf treatment near the walls (running for a bit more the simulation and see what happens remains also an option).
Best
V.
Old   October 12, 2011, 14:13
Hi vkrastev
concerning div(tauMC) I now think, that I remember that Openfoam returned an error when I tried the upwind scheme. But your explanation is pretty convinient.
short Update:
For the laplacianSchemes it is possible to choose cellLimitedSchemes. If I understand the intention correct, theses Schemes reduce fluctuations by limiting the gradient between neighbouring cell centers. (found a very good explanation http://www.cfd-online.com/Forums/ope...lllimited.html )
so I changed my fvSchemes as follows:
gradSchemes
default none;
grad(p) cellLimited leastSquares 0.9;
grad(U) Gauss linear;
grad(rho) cellLimited leastSquares 0.9;
grad(rhoU) cellLimited leastSquares 0.9;
grad((1|psi)) Gauss linear;
grad(e) Gauss linear;
grad(sqrt(((Cp|Cv)*(1|psi)))) Gauss linear;
grad(T) Gauss linear;
grad(omega) Gauss linear;
grad(k) Gauss linear;
The reason was, that pressure/density are probably the ones causing trouble.
It now seems (! no long time confirmation) as if the pressure oscillations are diminishing. See pictures below
Old   October 12, 2011, 23:15
Alberto Passalacqua
div(tauMC) must be discretized with a central scheme, since it does not introduce directional bias. Direction-biased schemes are appropriate only for convection.
Best,
Alberto Passalacqua
Old   October 12, 2011, 23:35
Alberto Passalacqua
Hi vkrastev
short Update:
gradSchemes
default none;
I would systematically apply the same limiter (I'd suggest cellLimited leastSquares 1 to all the gradients. Notice that the number here has a different effect in comparison to the effect it has in Laplacian and snGrad! 1 does NOT mean you do not limit.)
Best,
Alberto Passalacqua
Old   October 13, 2011, 05:26
Vesselin Krastev
Best,
That is my point too.
Old   October 13, 2011, 08:58
Hey Foamers,
I did as alberto suggested:
gradSchemes
default cellLimited leastSquares 1;
The result got much better after that as you can see below. But the fluctuations haven't vanished completely.
So I'll now try the Spalart-Almaras model and see what happens then.
File Type: jpg rhoCentralFoam_afterCellLimited_T0_3701.jpg (61.1 KB, 109 views)
sharonyue likes this.
Old   October 13, 2011, 09:33
Vesselin Krastev
Just a short add-on from my side: it seems (at least in my internal flow case) that Tadmor's flux scheme is more stable than Kurganov's one (probably because it's slightly more dissipative, at least as I was able to understand from Kurganov and Tadmor's original paper).
Regards
V.
Old   October 13, 2011, 11:19
Hi Foamers,
as I'm running the Spalart-Almaras model I get the following warning:
--> FOAM Warning :
From function tmp<volScalarField> SpalartAllmaras::k() const
in file SpalartAllmaras/SpalartAllmaras.C at line 262
Turbulence kinetic energy not defined for Spalart-Allmaras model. Returning zero field
I had a look at the source code, but as my c++ is worse than my Chinese I can really tell what is happening there.
The Spalart-allmaras model doesn't need the kinetic turbulent energy at all. So I don't understand why the model is creating a field k mit zero entries.
00241 tmp<volScalarField> SpalartAllmaras::k() const
00242 {
00243     WarningIn("tmp<volScalarField> SpalartAllmaras::k() const")
00244         << "Turbulence kinetic energy not defined for Spalart-Allmaras model. "
00245         << "Returning zero field" << endl;
00246
00247     return tmp<volScalarField>
00248     (
00249         new volScalarField
00250         (
00251             IOobject
00252             (
00253                 "k",
00254                 runTime_.timeName(),
00255                 mesh_
00256             ),
00257             mesh_,
00258             dimensionedScalar("0", dimensionSet(0, 2, -2, 0, 0), 0)
00259         )
00260     );
I would like to understand that. Especially because when I ran the incompressible case, I didn't get that warning. In the incompressible Spalart-Allmaras code there is a similar line than the one shown above.
Old   October 13, 2011, 11:41
Vesselin Krastev
That piece of code is missing in OF 1.7.1 (which is my reference version), and I really don't understand why is there in OF 2.0.0/1/x ... I think you can ignore the warning message without any consequence for your calculations. Anyway, have you tried the Tadmor scheme instead of the Kurganov one?
Regards
V.
Old   October 13, 2011, 13:01
Hi vkrastev
just changed to Tadmor, but it does not seem to change the fluctuations.
As the fluctuations are spacial, I'm thinking the problem might be connected to fvSolution. Maybe I gonna try
solver          PBiCG;
preconditioner  DILU;
instead of diagonal. What do you think?
Old   October 13, 2011, 13:05
Vesselin Krastev
No, I don't think you should change the diagonal solver options for rho, rhoU and rhoE, because as far as I have understood a little the rhoCentralFoam algorithm, these quantities are solved explicitly via the Kurganov/Tadmor reconstrucion procedure. What about the Spalart-Allmaras model compared to the kOmega?
V.
Old   October 13, 2011, 13:43
Hi vkrastev
my actual case is running with spalart-Almaras. As you can see below, the Amplitude of the fluctuations diminished a little bit.
The position of the shock probably becomes better after some time, thats at least what normally happens.
I'm open for new ideas ... thanks a lot
Old   October 13, 2011, 13:52
Vesselin Krastev
Hi vkrastev
I think that you have to let the simulations go ahead until at least the shock position becomes sufficiently stable for both models and then make some comparison. In the end your results appear not bad, and honestly I don't have at the moment other suggestions for smearing out those little oscillations...
Regards
V.
Old   October 14, 2011, 11:11
So after waiting for ages I reached a time of 0.186 and you're the oscillations are slowly decaying, as you can see below. So I'm going to wait a little longer.
I got some input from my supervisor and she thinks the problem I have here is a odd even decoupling. I'll have a look at the literature, see what I find out about it and if there's a way to get better results
Old   October 14, 2011, 11:38
Vesselin Krastev
Do you mean a pressure-velocity decoupling? This could be interesting, but honestly I can't say if it is a reasonable hypothesis...Anyway, if I understand you properly, the pressure-velocity coupling in the rhoCentralFoam solver occurs in the inviscid part of the solution, which is driven by the Tadmor/Kurganov algorithms: so the answer to the question would be inside the nature of such algorithms, which (at least to my actual knowledge of compressible flow solution procedures) are quite a mystery to me, so you'll have to face it all by yourself..Good luck!
V.
Old   October 14, 2011, 11:41
Yes it's about a pressure velocity decoupling.
thanks a lot for all your help until now. I'll let you if I find anything out, but maybe I can unmystify it a little bit ;-)
Have nice weekend.
regards from Munich
Old   October 25, 2011, 05:12
ndr
ndr is on a distinguished road
Hi schwermetall,
I observed something very similar to this when simulating a supersonic channel flow using rhoCentralFoam and kOmegaSST. The wall pressure at top and bottom walls of the channel is fluctuating a lot and it looks a lot like in your profiles. However, temperature and velocity profiles along the channel are fine, so it only seems to be a pressure problem.
I did as you suggested and changed to cellLimited for grad schemes: It helped, but the fluctuations are not completely gone. As I am usually using grids with y+ of around 30 and wall functions I tried to refine the grid. For y+ = 15 and wall functions the instabilities looked weaker. And when I deactivated the wall functions for a fine grid of y+ = 1 also the pressure fluctuations were gone completely. However, the results now seem to suffer quite a lot from numerical dissipation and are considerably less accurate in temperature and velocity profiles.
Did you try to refine your grid at the walls? It would be interesting to see if you can observe the same behaviour of the solver for your NACA case.
ndr is offline   Reply With Quote
mach number and selection of the fluent solver turbinesv FLUENT 4 April 24, 2011 01:14
How to find Mach Number Tobias FLUENT 2 October 18, 2005 10:59
non-dimensional analysis in Fluent Endee FLUENT 8 September 7, 2005 17:16
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Strouhal number of an airfoil Tim Franke Main CFD Forum 0 April 4, 2000 04:10
