Library files
Old   October 7, 2011, 05:58
Default Library files
A.D.E is on a distinguished road
Can I view the contents of any of the lib.so files?
I would like to see how for example OpenFoam calculates the Cl and Cd coefficients.
Thanks,
A.D.E
A.D.E is offline   Reply With Quote
Old   October 7, 2011, 06:18
Bernhard
Bernhard is on a distinguished road
The libraries are compiled from /src. What name a library will get is defined in all the Make/files. For example, is you want to find where libsampling.so is defined, you can execute a search command in the shell like
src> grep sampling `find -name files`
Good luck!
Bernhard is offline   Reply With Quote
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
