IOField<List<scalar > >
Old   October 6, 2011, 07:38
Default IOField<List<scalar > >
heavy_user is on a distinguished road
Hey Foamers,
i would like to add some information to my particles.
Therefore I added a member "List<scalar> myList" to myparticle class.
So each instance/particle will have that list.
I would like to write out that data so i tried to add that to the mypartticleClassIO.C file.
When I compile I get an error message and im am stuck right now..
/// in myParticlesClassIO.C
//this one works:
	  IOField<scalar> m(c.fieldIOobject("m",IOobject::NO_READ),np);
//this one not:
    	  IOField<List<scalar > >  myList(c.fieldIOobject("myList",IOobject::NO_READ),np);
And i get the error message:
/opt/openfoam171/src/OpenFOAM/lnInclude/Field.H:87: error: no type named ‘cmptType’ in ‘class Foam::pTraits<Foam::List<double> >’
So two questions:
1.) How do I add a lot of scalars (lets say 50-100) to my particle class, so that i have proper IO ?
2.) If the answer is list, how do I manage the IO?
Thanks!!
heavy_user is offline   Reply With Quote
Old   June 19, 2012, 17:29
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
I hope my response is not too late. I do not know what you need exactly but a scalarField works for the IOField so as vectorField and symmTensorField
IOField<scalarField> matHistoryScalar(
				      IOobject
Best Regards
Hisham
Hisham is offline   Reply With Quote
Old   July 24, 2017, 06:03
Fengli Shen
qiang92 is on a distinguished road
I also meet the problem right now. Did you solve you problem, I don't want to write Ifstrem to output the data of some variables which it not vetor or scalar defined in OpenFOAM. I create a FixedList<scalar, 5> a, variable a, I can output it through the way IOField.
If you solve your problem, please reply to me. Thanks
qiang92 is offline   Reply With Quote
Old   July 26, 2017, 05:45
Fengli Shen
I solved my problem using IOList instead of IOField,the full name of the type is IOList<scalarList>
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM Programming & Development 1 February 16, 2011 21:52
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM 0 December 16, 2010 08:08
CAD -> gMsh -> enGrid -> OpenFOAM Problem AlGates OpenFOAM 7 August 6, 2010 13:46
[Netgen] Geometry > Netgen > OpenFOAM ericnutsch OpenFOAM Meshing & Mesh Conversion 9 February 22, 2010 08:39
Point Data -> Spline -> Iges Tim Franke Main CFD Forum 1 July 6, 2000 13:14
