Problems with simpleFoam
Old   October 4, 2011, 09:52
Default Problems with simpleFoam
Samuele Z
samiam1000 is on a distinguished road
Dear all,
when I try to run simpleFoam (to simulate wind over terrain - let's say that I am using the turbine siting tutorial, changing the stl fil!) I get this error:
sammy@nash:~/Desktop/mesh_test/cases/suisse$ simpleFoam
|  \\    /   O peration     | Version:  2.0.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 2.0.1-cce6c678443c
Exec   : simpleFoam
Date   : Oct 04 2011
Time   : 14:48:43
Host   : nash
PID    : 20118
Case   : /home/sammy/Desktop/mesh_test/cases/suisse
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3   in "/lib/x86_64-linux-gnu/libm.so.6"
#4  log in "/lib/x86_64-linux-gnu/libm.so.6"
#5  Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField::updateCoeffs() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#6  Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField::atmBoundaryLayerInletVelocityFvPatchVectorField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#7  Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::incompressible::atmBoundaryLayerInletVelocityFvPatchVectorField>::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#8  Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam"
#9  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam"
#10  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam"
#11  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam"
#12  Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam"
#13
#14  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#15
Floating point exception
Could anyone help?
Thanks a lot,
Samuele.
PS: the mesh is ok (the command chackMesh says this!)..
samiam1000 is offline   Reply With Quote
Old   October 4, 2011, 12:21
Philipp Hofemeier
philipp. is on a distinguished road
Hello Samuele,
there seems to be a problem with the "Reading/calculating face flux field phi". Maybe you should check your initial and boundary conditions again. For more help you probably need to post more details.
Regards, Philipp
philipp. is offline   Reply With Quote
Old   October 4, 2011, 12:22
Samuele Z
Hi Philipp,
I can share my case, if you want. Maybe it is better to copy in a message just few files. Please, tell me which files I should post in order to allow you to help!
Thanks,
Samuele
Old   October 4, 2011, 14:32
Philipp Hofemeier
Hello Samuele,
I just checked the tutorials - you are using OF2.0.1, right? There is a turbineSiting tutorial for the windSimpleFoam solver. Maybe you should use that solver...
If that does not work, which files you edited and which are like the ones of the tutorial.
Philipp
Old   October 4, 2011, 14:57
Samuele Z
Dear Philipp,
it is curios that I get the same errore using the solver windSimpleFoam.
Also, if I use the file terrain.stl (the one that you can find in the turbineSitting tutorial) the command simpleFoam in my case works.
So, let me copy here all my files.. That's very strange, imho..
Here are the files:
1. epsilon
|  \\    /   O peration     | Version:  1.7.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
#include        "include/initialConditions"
internalField   uniform $turbulentEpsilon;
boundaryField
    #include "include/ABLConditions"
    "terrain_.*"
        type            epsilonWallFunction;
        Cmu             0.09;
        kappa           0.4;
        E               9.8;
        value           $internalField;
    outlet
        type            zeroGradient;
    inlet
        type            atmBoundaryLayerInletEpsilon;
        Ustar           $Ustar;
        z               $zDirection;
        z0              $z0;
        zGround         $zGround;
    ground
        type            zeroGradient;
    #include "include/sideAndTopPatches"
2. p
|   \\  /    A nd           | Web:      http://www.OpenFOAM.com               |
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $pressure;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
    "terrain_.*"
        type            zeroGradient;
    ground
        type            zeroGradient;
3. nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    "terrain_.*"
        type            nutkRoughWallFunction;
        Ks              0.2; //Ks = 20 Z0
        Cs              0.5;
        value           uniform 0.0;
    ground
        type            calculated;
        value           uniform 0;
4. k
FoamFile
    version     2.0;
    format      ascii;
    object      k;
internalField   uniform $turbulentKE;
boundaryField
    outlet
        type            inletOutlet;
        inletValue      uniform 0.0;
    inlet
        type            fixedValue;
    "terrain_.*"
        type            kqRWallFunction;
        value           uniform 0.0;
    ground
        type            zeroGradient;
5. U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform $flowVelocity;
boundaryField
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    inlet
        type            atmBoundaryLayerInletVelocity;
        Uref            $Uref;
        Href            $Href;
        n               $windDirection;
        z               $zDirection;
        z0              $z0;
        zGround         $zGround;
    "terrain_.*"
        type            fixedValue;
        value           uniform (0 0 0);
    ground
        type            fixedValue;
6. ABLConditions
Ustar                0.82;
Uref                 10.0;
Href                 20;
z0                   0.1;
turbulentKE          1.3;
windDirection        (1 0 0);
zDirection           (0 0 1);
zGround              935.0;
7. initialConditions
flowVelocity         (0 0 0);
pressure             0;
turbulentKE          1.3;
turbulentEpsilon     0.01;
8. sideAndTopPatches
top
    type slip;
sides
    type slip;
Old   October 5, 2011, 06:30
Philipp Hofemeier
Hi Samuele,
if it works with the stl-file of the tutorial there has to be a problem with your file respectly with your mesh. Even if checkMesh says that the mesh is ok there still can be problems. Maybe you can use a simpler geometriem at first.
Otherwise you can try different initial and boundary conditions. Maybe that will help.
Philipp
Help! problems in calculating forces with SimpleFoam DLC OpenFOAM 3 April 26, 2022 00:43
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Convergence Problems SimpleFOAM Kutti OpenFOAM 16 June 14, 2010 09:12
Convergence problems with simpleFoam on human airway CedricVH OpenFOAM Running, Solving & CFD 8 June 3, 2010 10:05
convergence problems using simpleFoam sebbi OpenFOAM Running, Solving & CFD 3 November 25, 2009 16:27
