Gasflow into vacuum
Old   October 4, 2011, 06:18
Question Gasflow into vacuum
Max
PussInBoots is on a distinguished road
I'm totally new to CFD and thus to OpenFOAM. I've been playing around with the tutorials for quite a time and wanted to start simulating my own problem now.
For my job at a university group in Hamburg (Germany) I should simulate the flow of an ideal gas through a nozzle into a vacuum chamber.
On my first tries I got lots of errors (mostly to high Courant numbers) while trying to adapt the "compressible/sonicFoam/laminar/forwardStep" to my mesh and testing it.
1) Is sonicFoam able to simulate such a flow?
2) which boundary conditions are the best for simulating an input of some bars of pressure and how to model the vacuum chamber?
Unfortunately didn't I find appropriate answers in existing threats.
Thanks
Max
PussInBoots is offline   Reply With Quote
Old   October 17, 2011, 11:35
Eric M. Tridas
eric.m.tridas is on a distinguished road
Hey Max,
I'm working on a similar project where I am simulating air flow into a vacuum chamber through a controlled leak (0.5 mm ID capillary). I used rhoCentralFoam to get a transient solution. I'm not done with the project yet but I have obtained some reasonable results.
You may want to check out the LadenburgJet60psi tutorial in the rhoCentralFoam section. This helped me greatly when I was first starting.
I hope this helps! Keep me updated as it is always good to be in touch with others working on similar projects.
Regards,
Eric
eric.m.tridas is offline   Reply With Quote
Old   October 19, 2011, 09:06
Max
Hey Eric,
thanks for your reply. I'll keep you posted as soon as I make any progress.
Regards,
Max
Old   May 3, 2013, 17:29
Default create vacuum inside chamber....!!???
Sumeet Kotak
sumeet kotak is on a distinguished road
Hello Max and Eric
I am doing my M.tech Project at Mumbai University,India. I am simulating vacuum chamber in my simulation.
I am working on Physical vapor deposition. To improve coating quality I have to maintain vacuum of level 0.005 pascal and my geometry is a vertical cylinder of 300 mm dia and 640mm height and horizontal cylinder of 100 mm height and 150mm dia is connected with the vertical cylinder at the height of 150mm from the bottom. the horizontal cylinder on another side is connected with vacuum pump which create vacuum of 0.005 pascal.
I have given boundary condition as pressure outlet.
So can you please help me how should I set my operating pressure and gauge pressure for pressure outlet BC so I can maintain 0.005 pa vacuum inside the chamber.
I am simulating my problem using species transport model with volumetric reaction.
waiting for replay
thanks in advance
sumeet kotak is offline   Reply With Quote
Old   June 11, 2017, 02:36
Bharatvaaj
Vaaj is on a distinguished road
Originally Posted by sumeet kotak View Post
Hello Max and Eric
waiting for replay
thanks in advance
Hey did you have any luck in knowing how to set operating pressure and gauge for BC for this vacuum conditions? I am dealing with similar problem
Thanks in advance
Vaaj is offline   Reply With Quote
Old   June 11, 2017, 05:37
Default Beware of Kn >> 1
Bernhard Linseisen
Linse is on a distinguished road
Dear Vaaj,
Although the topic is rather old, I wish you the best of luck with getting good answers!
Unfortunately I cannot answer your main question.
But I would like to remind of a critical piece of the analysis:
Be careful about the different requirements for a simulation with the different solvers! Most of the OF-solvers are based on the continuum-approach, requiring a Knudsen number << 1 for giving scientifically meaningful results!
For the briefest of informations, have a look at http://www.thermopedia.com/content/908/
Cheers,
Bernhard
Linse is offline   Reply With Quote
boundary conditions, gas, sonicfoam, vacuum
radiation modeling in vacuum mirko OpenFOAM Programming & Development 7 May 20, 2016 09:31
Assistance in Vacuum pump simulation enr_venkat CFX 5 November 20, 2012 12:50
Vacuum with two-phase flow Ahmed Khattab FLUENT 2 August 8, 2010 12:38
Radiation in vacuum nitin CFX 0 July 6, 2009 02:49
oxygen lance simualtion in vacuum rensb FLUENT 0 July 17, 2006 03:14
