Solving PDE time dependent
Old   September 30, 2011, 06:42
Default Solving PDE time dependent
DiracRules is on a distinguished road
Hi there!
I'm looking for a way to solve parabolic time dependent PDE (sth like Ut=Uxx).
Actually, I'm trying to write down my own solver since I need to perform some peculiar calculation, so what I'm asking is:
what kind of loop/iterative method should I use?
Since I'm quite new to CDF, I don't know all the possibilities and the different type of loops.
Thanks in advance!
DiracRules is offline   Reply With Quote
Old   September 30, 2011, 06:53
Nima Samkhaniani
nimasam is on a distinguished road
hi firend
openFOAM solves pde equation for learning look into basic solver!
for example a syntax like this in OpenFOAM can solve ur problem
solve (fvm::ddt(U) == fvm:: laplacian (U))
for more information about openFoam syntax look at programmer guide chapter 2
nimasam is offline   Reply With Quote
Old   September 30, 2011, 12:38
Thank you!
I am ashamed of my question. Just did not think enough. It was obvious. I had already written that line of code, I just thought I needed something more "complicated" -.-''
And can you give me some info about solving eigenvalue problems (like Uxx=lambda *U?
I need the solver to find both lambda and U.
I thought something like making a loop on lambda and see which solutions are non-zero, but I don't think it would work and I guess there are less expensive ways.
Thx
loop, pde, solver
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
