Shadow Wall/Thermo Baffle in OF 1.7.1
Old   September 29, 2011, 20:09
Default Shadow Wall/Thermo Baffle in OF 1.7.1
ak
newOFuser is on a distinguished road
Hello Foamers,
Does anyone know how we can define shadow walls/baffles in OF 1.7.1? Is there some tutorial available for this?
I am interested in including wall heat transfer (where the wall thickness and its properties can also be defined) and therefore was looking into how it could be done in OF 1.7.1
Any thoughts on this?
Many thanks,
amit
newOFuser is offline   Reply With Quote
Old   March 1, 2012, 18:17
Stefano Wahono
swahono is on a distinguished road
You can not do this in OF 1.7.x.
OF 2.0.x can do this.
You need to create your wall mesh with -shadow wall patch already included.
The easiest way to do this is to use third party mesher.
Then you need to change your constant/polyMesh/boundary for your coupled wall
wall1
    type            directMappedWall;
    nFaces          32482;
    startFace       16477771;
    sampleMode      nearestPatchFace;
    sampleRegion    region0;
    samplePatch     wall1-shadow;
    offsetMode      uniform;
    offset          ( 0 0 0 );
wall1-shadow
    nFaces          32482;
    startFace       16510253;
    samplePatch     wall1;
    offsetMode      uniform;
    offset          ( 0 0 0 );
Then for 1D heat conduction through the wall, use the BC:
wall1
        type            compressible::temperatureThermoBaffle1D<constSolidThermoPhysics>;
        baffleActivated yes;
        thickness       uniform 0.001;
        Qs              uniform 0;
        transport
            K               202.4;
        radiation
            sigmaS          0;
            kappa           0;
            emissivity      0;
        thermodynamics
            Hf              0;
            Cp              871;
        density
            rho             2719;
        value           uniform 300;
    wall1-shadow
        $wall1    ;
then include additional library in your system/controlDict
libs ("libthermoBaffleModels.so");
For 3D heat transfer through the wall (i.e. 1D conduction + 2D shell conduction)...
things are a bir more complicated. But, you can definitely do it too.
Stefano Wahono
Defence Science and Technology Organisation
Propulsion Systems
swahono is offline   Reply With Quote
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
OpenCFD release OpenFOAMŪ version 1.7.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2010 12:40
Wall-wall shadow Ness FLUENT 0 March 7, 2007 05:00
Boundary baffle error 258 Nalleli Siemens 2 November 19, 2006 14:14
baffle in flow route GaryWang CFX 0 October 24, 2005 00:19
