foamToTecplot360 - Zones Missing(!)
Old   September 29, 2011, 09:35
Default foamToTecplot360 - Zones Missing(!)
camoesas is on a distinguished road
HI,
I am using foamToTecplot360 to export OpenFoam Data to tecplot. But opening my file in tecplot I just have: region0*
And I am missing: inlet outlet walls hotwall etc....
Anybody faced the same problem? Is there an alternate skript for foamToTecplot360?
Thanks
Camoesas
camoesas is offline   Reply With Quote
Old   September 30, 2011, 02:23
HI Everybody,
I am glad I am able to answer my question now. I will summarize all steps to use tecplot360:
1. to get the function foamToTecplot360 run, follow the steps descriped here, in post #16 / #17
2. run foamToTecplot360 (it will produce a folder "Tecplot360" and in this a subfolder "boundaryMesh")
3. Open Tecplot and then click > load Files > Tecplot Data loader > choose Multiple Files > pick first the file "..._grid_0.plt" > and then select "...X.plt" (described anywhere here)
4. In a final step load more data files (with the "add to current..." option) and choose in the subfolder "boundaryMesh" the mesh files: "boundaryMesh_x.plt" (that is what brought my boundary layers back)
Skipping Zones 1337Hal FLUENT 1 June 27, 2022 09:33
merge zones Domi FLUENT 2 May 3, 2019 13:15
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 15:42
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
about seperating zones Bono FLUENT 1 October 8, 2005 06:08
