September 29, 2011, 06:29 |
blade induced flow simulation
Mehran Saeedi
Rep Power: 16 |
Hello everebody,
I'm currently trying to simulate flow induced by blade rotation using OpenFoam. I am using pimpleFoam as the base solver and trying to change that a bit mesh motion part. I have a cylindrical domain with a blade in the middle and at each time step I rotate all the points, corresponding to a fixed angular velocity. Then I save point motions in pointMotionU field. I got the correct mesh rotation and mesh point velocities are also correct but the velocities I get inside the domain are very small, order of e-10!!! pointMotionU field for blade points have the same velocity as r * Omega but U field for those points and even their neighbour points is very small. Any hint is highly appreciated. Regards, Mehran |
October 27, 2011, 04:24 |
Jason Eason
Rep Power: 16 |
I have a similar case, how did you view the induced flow? I used the MRFSimpleFoam solver, I created an atmosphere patch around my rotor, but thats not working for me.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0 |
Need suggestion about simulation of plasma induced flow | mukut | Main CFD Forum | 2 | July 28, 2020 15:21 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
Need help about Flow simulation by using PHOENICS! | mukut | Phoenics | 1 | September 24, 2010 08:08 |
About unsteady flow simulation | Ji | Fidelity CFD | 3 | June 10, 2003 11:04 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
