A few simple questions about linearUpwind and limitedLinear
Like Tree46Likes
Old   May 8, 2018, 08:22
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
So I am currently busy but if no ready unswer will come, I have to look into the code
Originally Posted by alimea View Post
Hi Alexander
I haven't tested this, but theoretically yes. you are right. According to this sentence of cfd.direct:
limitedLinear: linear scheme that limits towards upwind in regions of rapidly changing gradient; requires a coefficient, where 1 is strongest limiting, tending towards linear as the coefficient tends to 0.
https://cfd.direct/openfoam/user-guide/fvschemes/
Tobi likes this.
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   June 15, 2021, 20:13
s.v
s.v
s.v is on a distinguished road
Sorry I have not read everything in this thread carefully but my PhD thesis (which can be downloaded from this link -- https://drum.lib.umd.edu/handle/1903/21883) discusses both these schemes reasonably well I think -- see information around page 27 in my thesis for linearUpwind and information around pages 34-35 for limitedLinear ....
Some other schemes are also reasonably well discussed in there (for example LUST, Gamma) ....
Most of the schemes are discussed through the NVD diagram which provides some useful insights ....
Convergence speed for different schemes is also discussed a little bit in there ....
Cheers ....
gigili206, saladbowl and DevilX like this.
s.v is offline   Reply With Quote
Old   June 17, 2021, 03:57
Daniel
DevilX is on a distinguished road
Just a small question: in your thesis you use fx in eq. 2.23 - is it the gradient in x direction or what is ist? Thanks!
DevilX is offline   Reply With Quote
Old   June 17, 2021, 08:33
s.v
s.v
Hello Daniel -- fx is described in the LUST scheme section (page 28, text below equation 2.15) -- I have pasted some of that text below:
"f x represents the mesh non-uniformity in the direction of the vector r. For
uniform grids (for which f x = 1/2)"
Old   June 21, 2021, 09:27
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear Dr. Vakhrushev,
did you investigate into that topic and did you get a reasonable answer? I was expecting more or less the same result as you wrote. Using a limiter of 0 should be identical to linear.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 21, 2021, 09:47
s.v
s.v
Hi Tobias:
I am guessing the reason why "linear" and "limitedLinear 0" do not give identical results is because "limitedLinear 0" becomes upwind outside the Convection Boundedness Criterion (CBC) region on the NVD diagram -- see for example the discussion and figures around page 35 in my thesis (https://drum.lib.umd.edu/handle/1903/21883) ....
This thread (TVD schemes, questions about limitedLinear) also discusses the same issue and I wrote a similar answer there as well (see post #23) ....
I hope this helps ....
anaspauzi likes this.
Old   June 21, 2021, 11:17
Tobi's Avatar
Tobias Holzmann
I am not too much into the single discretization schemes and its pro/cons. I would need to investigate into the OpenFOAM code to understand the real difference. However, if you say some parts go to upwind rather than linear, it should be obvious.
You thesis already had more downloads than mine will get until 2200
Well. Regarding to your thesis, k represents the limiter, right? So k = 0 is a "bounded linear (central differencing)" scheme. However, I need some time to go through the stuff (whenever I will find the motivation :P )
Keep foaming,
Tobias Holzmann
Old   June 21, 2021, 11:39
s.v
s.v
When I did my thesis -- I looked at the code and wrote the equations for the different schemes ....
To confirm that I am reading the code correctly I remember I wrote a small OpenFOAM utility that gave me the face values directly ....
Then I compared the face values given by the equations and the OpenFOAM utility with a simple python or Matlab script -- they were within machine precision as far as I remember -- so I am quite confident about the equations given in my thesis ....
And yes k is the limiter/coefficient and can go from 0 to 1 ....
Tobi likes this.
Old   March 30, 2024, 03:44
bany
bany is on a distinguished road
Originally Posted by Anne Lincke View Post
Dear Dan, Dear Foamers,
I found your post which is very interesting for me.
Could you please tell me how one can derive the equation above?
I found this equation implemented in OpenFOAM, and in Fluent it is obviously the same.
But I have problems in understanding this equation.
For LUDS (linear upwind) we discretize the face value as
\phi_f = \phi(C) + 0.5 (\phi(C) - \phi(U))
How is the implemented formula connected to that?
Thank you very much for an answer in advance!
Anne
In OpenFOAM, limitedLinear: T_f =psiT_{UD} +(1-psi)T_{CD}
linearUpwind: T_{f} =T_{P}+\phi grad(T)_{p}r
When I output the matrix created by fvm::div(phi, T) through fvScalarMatrix divphi_tmp(fvm::div(phi, T));, I found that the values of divphi_tmp.diag(), divphi_tmp.lower(). divphi_tmp.upper() are identifical no matter which schemes (i.e., upwind and linearUpwind) are used in fvSchemes, expect for divphi_tmp.source().
Where, \phi is a limiter, grad(T)_{p} is the gradient of T at the cell centroid P. How to calculate the grad(T) at the centroid? OpenFOAM will search the gradScheme in fvSchemes. For the Gauss linear scheme, grad(T) is computed by the sum of the product of T_{f} (i.e., T at faces around the cell P), direction vector and area respectively in the x, y, z directions, as explained in https://www.youtube.com/watch?v=oeA1Bg9GqQQ. So the contribution of fvm::div(phi, T), when using linearUpwind, enters TEqn.source() from the grad(T)_{p}.
So, the grad(T) is computed by T_{f}, and the grad(T) in the linearUpwind scheme contributes the divphi_tmp.source(). If grad(T) is computed by (T_{P}-T_{N})/d like \phi_f = \phi(C) + 0.5 (\phi(C) - \phi(U)), the contribution of fvm::div(phi, T) will affect divphi_tmp.lower() and divphi_tmp.upper(), and not affact divphi_tmp.source().
bany is offline   Reply With Quote
limitedlinear, linearupwind
linearUpwind scheme in OpenFOAM 2.0.1 ??? cabul OpenFOAM 8 November 9, 2011 07:57
