simulate a gas turbine combustor with dieselFoam
Old   September 23, 2011, 21:32
Default simulate a gas turbine combustor with dieselFoam
enrico bighè
kikko is on a distinguished road
Good evening of everybody,
I have simulate a gas turbine combustor using dieselFoam but the solution doesn't remain costant....What change have I to do???help me..
The combustor works with a kerosene mass flow rate of 0.035 kg/s and air mass flow rate of 1.5 kg/s. The combustor is 350 mm long and d_parcels of spray is 50 micron...
thank you
kikko is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
Gas turbine load problem hashimbukhari Main CFD Forum 2 July 24, 2010 04:48
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
